paint work question
Old Mar 1, 2014 | 08:05 PM
LHD220Turbo's Avatar
LHD220Turbo
Default paint work question
Evening all;
got a red astra which has gone slightly pink on some panels; ive used t cut before to bring them back up but i havent got any left. i've got a big tub of cutting compound called G3. Can i use this to bring it back?
Its been years since i used it, from memory do you have to use water with it?
Old Mar 1, 2014 | 08:09 PM
RSmark84's Avatar
RSmark84
Better of using something like Megiuars 205/105 compound. Much better product and i'd use a machine polisher.
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
You can use it without water but its normally a bit harsh, so I would recommend using water with it to soften the blow to the paintwork, you could also wet sand it first with 2000 if the paintwork is still solid
Old Mar 1, 2014 | 08:12 PM
RSmark84's Avatar
RSmark84
When I did my brothers 306 daily smoker I found 2000 way too harsh. 5000 or 7000 would be better. But i'm not sure how well Vauxhall paint their cars.
Old Mar 1, 2014 | 08:13 PM
LHD220Turbo
to be honest i havent got the patience for paintwork, its only a cheap motor so not wanting to buy any more products, will just use what i've got.
i take it i only use a light spray of water rather than soaking the cloth & panel?
Old Mar 1, 2014 | 08:15 PM
gingerturbo
I normally apply the g3 to a damp cloth/pad
Old Mar 1, 2014 | 08:17 PM
LHD220Turbo
thanks; i'll give it a go tomorrow and see what happens - ill be doing it by hand as havent got a polisher machine
Old Mar 1, 2014 | 08:19 PM
costina's Avatar
costina
Live long and prosper!!
you got a polisher? ive one here you can borrow. I use it wet but its better to mask the shut lines and any vents or you will be cleaning it off for a week.
Once cut use a good polish to protect.
Give us a ring if you need it.
Old Mar 1, 2014 | 08:20 PM
costina's Avatar
costina
best I dig it out then.
Old Mar 1, 2014 | 08:23 PM
gingerturbo
Yes top tip lol it's messy gear
Old Mar 1, 2014 | 08:38 PM
LHD220Turbo
cheers Paul; i'll see how i go first on one panel then give you a shout if i need it, if thats alright.
My thinking was a polishing machine would flick the g3 everywhere! but doing it by hand ive got a bit more control.
Ive taken off the weather strips on the doors and the plastic trims that go from back off roof & down the windscreen
Old Mar 1, 2014 | 08:42 PM
costina's Avatar
costina
Mate you will be there forever without a machine trust me been there.
I can drop it off about 11.50 as I got to pick up wifes mum.
its up to you
Old Mar 1, 2014 | 08:43 PM
LHD220Turbo
ill text you Paul mate in the morning; i;ll see how i go. cheers
Old Mar 1, 2014 | 08:46 PM
costina's Avatar
costina
ok mate
Old Mar 1, 2014 | 09:35 PM
botters's Avatar
botters
competant bodger
get some 3m fast cut plus if you go from g3 to fast cut i guarantee you will never use g3 again ever! does twice the job in less than half the time and its far easier to clean up afterwards can be used dry too tho i use just a little water
Old Mar 2, 2014 | 08:53 AM
costina's Avatar
costina
This is good stuff which comes in different grades.
Billy_RS
16
Oct 11, 2025 09:41 PM
3i Jim
Nov 20, 2015 05:12 AM
borboyous
Aug 22, 2015 11:17 AM
