Sealing decompression plate
Old Feb 17, 2014 | 08:38 AM
perry3188's Avatar
perry3188
Default Sealing decompression plate
I want to use a 1.5mm decomp plate with only 1 gasket between head and plate. Ferriday engineering say this is the best way, and they seal the plate to the block using a high temp sealant. They use alloy plates for this method though.
I can get either a mild steel or a stainless plate for £25 on ebay, but all the listings for stainless plates say to use 2 gaskets.
Can anyone tell me their experience with whatever arrangement they used? And what the sealant is I will need to bond the plate to the block?
2 gaskets sounds like a bad idea to me and I dont want to drop the compression too much as I'm only running 1 bar.
Cheers.
Old Feb 17, 2014 | 10:16 AM
markk's Avatar
markk
I would stick with what ever Mike says at Ferriday, he knows his stuff.
Old Feb 17, 2014 | 10:55 AM
coswurv's Avatar
coswurv
I used wellseal to do mine years ago, worked fine.
Old Feb 17, 2014 | 12:49 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
i have a ferriday decomp plate and a genuine Ford headgasket, no sealant used, and im putting 1.6 bar through it.
Old Feb 17, 2014 | 12:53 PM
perry3188's Avatar
perry3188
Are the plates your using stainless, mild or alloy?
Old Feb 17, 2014 | 12:54 PM
Adam.'s Avatar
Adam.
cant remember i just rang up Ferriday told them what i was doing and they sent it out
Old Feb 17, 2014 | 06:06 PM
perry3188's Avatar
perry3188
Anyone used a stainless plate sealed to the block Successfully? Or only Alloy?
Old Feb 18, 2014 | 08:23 AM
coswurv's Avatar
coswurv
Mine were stainless steal, I had a load laser cut back then.
Old Feb 18, 2014 | 09:16 AM
perry3188's Avatar
perry3188
What boost were you putting through It?
Old Feb 18, 2014 | 09:52 AM
coswurv's Avatar
coswurv
I can't remember mate was years ago now, I used sitech racing for my headgaskets.
Old Feb 18, 2014 | 08:57 PM
perry3188's Avatar
perry3188
bobsworth
77
Mar 24, 2016 09:30 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
