Arrrgggghhh, poxy hose
Old 24-03-2005, 09:19 PM
Escy
Escy's Avatar
Default Arrrgggghhh, poxy hose
i've spent over 1 hour in the dark struggling. does anyone have some tips for fitting a small pipe onto a big nipple?
i've got some braided water hoses that have plastic pipe inside them. the bore size is 6mm, but the nipple is designed to fit a 8mm hose.
i'm cutting my hand to shreds trying to fit it.
i've tried winding a bolt into it to open up the pipe, also tried boiling water.
neither have done the trick, any other ideas?
Old 24-03-2005, 09:25 PM
Rhys
Rhys's Avatar
only thing i can think of is to soak the nipple with WD40 and then heat the pipe up
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
If boiling water didnt help, I would say they aint gonna fit. Might be better to give up now while you still have your sanity.
Old 24-03-2005, 10:09 PM
Escy
Escy's Avatar
i've given up, the bastard has got the better of me.
what i need is a reducer fitting that will take a 8mm pipe one end and a 6mm the other. is there such a thing, and where can i get one from?
Old 24-03-2005, 10:32 PM
Christian and Beccy
#1 in Spelling Club
Easy. Lemans make those in Plastic. You can also get Metal ones. Should be easy to get hold of.
Old 24-03-2005, 10:40 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
i'd guess get the right size lol
Old 24-03-2005, 11:01 PM
Escy
Escy's Avatar
it was a custom made water feed. the guy only had 6mm bore pipes so my choice was limited. i assumed i'd be able to force it on.
i can't find the lemans website. do you know what it is? i've been on it in the past
Cheers, Tom.
Old 24-03-2005, 11:13 PM
vroooom ptssssh
It Wasnt Me!
done simmilar to a mk2 1.4 fiesta ghia, blocked off the heater matrix an joined 2 hoses with a bit of copper pipe Force was requiered lol
**edit im lying, it was a bit off a steering rack, 2 holes at top then one long pipe? bit off a steering rack we hacksawed then forced into place pmsl**
gcfcos
59
06-10-2015 05:04 PM
Fudgey
21
30-09-2015 06:19 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Arrrgggghhh, poxy hose
