Help Needed
Right folks; i have an erst
1.what is the easiest way totop up my gear oil?
2.the breather pipe that goes to the metering unit, is it the one from
rocker cover on the left hand side?
3. what is the easiest way to remove the radiator?
Cheers for the help
Cheers for the help
As above for the box - via the filler plug in the front of the box
For the rad undo top and bottom hoses unplug fans undo mounts and lift up and out
I always use an Oil Syringe.
Yes.
Its a long time since I had a Standard set-up, but if it wont come out from above then its Bumper off. Intercooler out. Bottom hose off to drain the Water. Top Hose off. Undo mounts. Bring the Radiator out through Front Panel.
Cheers for the help
Yes.
Cheers for the help
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
rog
Sep 4, 2015 12:10 PM
borboyous
Aug 22, 2015 11:17 AM
