seam welding
24-03-2005, 07:10 PM
seam welding
saph 4x4 chasing 600 bhp when done will i see any benefits
24-03-2005, 07:13 PM
Not unless you use it on track or it's a race car, no.
24-03-2005, 07:16 PM
will be having some abuse on track
24-03-2005, 07:17 PM
To have it done properly is hugely expensive, and you generally have to strip the car back to a bare shell.
24-03-2005, 07:22 PM
car already a bare shell so that not a problem thanks for input mate
24-03-2005, 07:23 PM
Is everything else going to be solidly mounted ? If not then no not really
24-03-2005, 07:30 PM
24-03-2005, 07:34 PM
If you're not going to put a full cage in, it will help the car become more rigid.
If you do put a cage in, you won't notice it over the stiffening effect of the cage.
Is it worth doing, absolutely.....especially if you already have it down to a bare shell
24-03-2005, 07:35 PM
Well the shell may be stiffer but is it still going to be bolted to the important bits with squishy rubber or nylon mountings
24-03-2005, 07:58 PM
A stiffer shell will make suspension adjustments more noticeable because the shell is not part of the damping system.
boeb
09-01-2020 05:11 AM
bobsworth
77
24-03-2016 09:30 PM
01-11-2015 06:53 PM
gcfcos
59
06-10-2015 05:04 PM
SMILER258
28-09-2015 09:04 AM
