Interference or non interference engine?
Old Jan 25, 2014 | 05:29 PM
ermir's Avatar
ermir
FOCUS
Default Interference or non interference engine?
Hi guys,
Does anybody know if a mk1 focus, petrol engine, 1.6 zetec se is a interference or non interference engine. I changed an oil seal in the crank shaft and the engine is now out of time(not synchronized any more) and im afraid i damaged any valve. i just tried to start it on and i heard a blast.
Old Jan 25, 2014 | 06:17 PM
Harryh24's Avatar
Harryh24
pretty sure they are interference and you need the pin set to time the up
petenete's Avatar
petenete
Interference
Old Jan 25, 2014 | 07:32 PM
DangerousBryan's Avatar
DangerousBryan
Most engines are interference. The focus definately is. If you haven't got the proper timing pins I wouldn't attempt one as neither the crank or cams are keyed.
Old Jan 25, 2014 | 07:33 PM
ermir's Avatar
ermir
FOCUS
Do you think i have damaged any valve? i just tried to start it up. Does it have any safety relay or block?
Old Jan 25, 2014 | 07:35 PM
DangerousBryan
No,there is no safety relay. Best you can do is time it up properly and see if it runs.
Old Jan 25, 2014 | 07:37 PM
ermir's Avatar
ermir
FOCUS
Thats the answer i dint want to hear.
Old Jan 25, 2014 | 07:38 PM
RichieST's Avatar
RichieST
Take the plugs out, turn the crank bolt over by hand and see if the engine turns freely.
Old Jan 25, 2014 | 07:51 PM
ermir's Avatar
ermir
FOCUS
I tried it before but with plugs on(you mean spark plugs or what?) and it doesnt turn
Old Jan 25, 2014 | 07:54 PM
DangerousBryan
Its hit then. Take the cam cover off and see if you can see anyrhing. You need the timing pins though.
Old Jan 25, 2014 | 07:59 PM
doga-ot's Avatar
doga-ot
hardly worth fucking about with the 1.6 engines are easily and cheaply got hold of whip it out and drop 2nd hand one in
Old Jan 25, 2014 | 08:05 PM
ermir's Avatar
ermir
FOCUS
yeah i know, but mine has only 60 k miles on. lets hope i dint make any damage. Pretty old mercedes days. Never had a problem with timing belts as it had a big thick steel chain!!! in this engine the crank shaft and the rotor were hold only by a single bolt.
Old Jan 25, 2014 | 08:08 PM
DangerousBryan
The belts are fine if you know what your doing! Good for 10 years or 125000 miles between changes
Old Jan 25, 2014 | 08:11 PM
ermir's Avatar
ermir
FOCUS
But if it runs ok, do you think it will have any non evident problem that can come out some miles after?
Old Jan 25, 2014 | 08:13 PM
DangerousBryan
No. If it runs properly I can't see there being a problem. But I think you will have damaged something if you tried starting it.
Old Jan 25, 2014 | 08:23 PM
ermir's Avatar
ermir
FOCUS
I tried just once for a sec. i heard a blast and i turned off the ignition immediately. it dint even start. so only the engine starter was involved
Old Jan 25, 2014 | 08:30 PM
Oranoco's Avatar
Oranoco
engine starter turns the engine so likely to have damaged it.
Old Jan 27, 2014 | 02:36 PM
ermir's Avatar
ermir
FOCUS
The engine is f....d. 12 banded valves and damaged block valve. piston head damaged.
Thinking of rebuilding the engine and sell it. Any idea of the 1.8 mk2 are they any good. My father owns a mk 2.5 pertol engine and it runs great. thanks.
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
