Ecu question
Old Jan 16, 2014 | 05:42 PM
RSGooner's Avatar
RSGooner
Default Ecu question
Hope someone can clear this up for me please, I carried out a 2.0 conversion to my mk3 cab, currently it has a 2fcd ecu, is this ok to use as I have been offered a deep ecu, would swapping make much difference? If so it it straight swap or do I need to change any wires? Thanks
Old Jan 16, 2014 | 05:58 PM
Oranoco's Avatar
Oranoco
iirc the 2 litre silvertop Zetec conversion requires a DEEP, DESK or DEWY ECU.
Old Jan 16, 2014 | 06:00 PM
RSGooner's Avatar
RSGooner
It's not silvertop, sorry maybe should have stated its the later plastic looking black top, runs ok on current ecu but wondered if deep ecu would up the power
Old Jan 18, 2014 | 01:19 PM
RSGooner's Avatar
RSGooner
Anyone help please?
Old Jan 18, 2014 | 01:58 PM
Mk4 Rick's Avatar
Mk4 Rick
As Oronaco said you will need the 2 litre ecu unless you find the RS1800 ecu.
Old Jan 18, 2014 | 02:01 PM
Mk4 Rick's Avatar
Mk4 Rick
Isnt the 2fcd the xr2i ecu? Might be worth an ask to a tuner to see if the ECU can be adjusted to meet the 2 litre requirements
Old Jan 18, 2014 | 02:34 PM
RSGooner's Avatar
RSGooner
I beleive it is mate, so in your opinion the deep would run it much better? Is it a straight swap over from 2fcd to deep or are pinouts the same do you know?
Old Jan 18, 2014 | 02:52 PM
Mk4 Rick's Avatar
Mk4 Rick
If I remember rightly the 2fcd was run on the XR2i CVH engine not zetec I think the CVH ran 95 or 98 bhp so you running the the 1.6 ecu on the 2litre engine yes it will run but the ecu wont fuel the car correctly it will most proberly run lean.Even if you did get the 2 litre ecu,desk deep or dewy you would need the maf to fuel it properly.I do believe the maf from the desk will work on the dewy and deep and vise versa.As for the looms you can do pin outs its been done on the Fiesta si loom and a few other models.
Old Jan 18, 2014 | 02:56 PM
Mk4 Rick's Avatar
Mk4 Rick
This thread might be of some use to you.Its the complete guide on a swap.I no its the fiesta but more or less the same thing in terms of wiring
http://www.fiestaturbo.com/forums/1-...04-07-vt92943/
Old Jan 18, 2014 | 03:10 PM
RSGooner's Avatar
RSGooner
Thanks, will have a read through that in a bit
chowfornow
14
Jan 5, 2019 09:01 PM
tankybaby66
Feb 6, 2016 02:24 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
