o2 sensor too close???
Old Dec 30, 2013 | 12:02 AM
higgsy91's Avatar
higgsy91
Zetec Turbo Baby Yeahhhh
Default o2 sensor too close???
Is this too close, i can't get the wires much further away than this.. its an innovate LC-1
the only way i can get more distance is by removing the bracket that holds the exhaust.. but then i won't be able to keep the exhaust still!
and as a bonus question for you PF'ers.. anyone know how the metal adaptor plate that goes between the thermostat housing on an RS, seals to the block?! can't see any gaskets for it on microcat or ebay?!
Cheers!
Old Dec 30, 2013 | 12:08 AM
davidfox280585's Avatar
davidfox280585
i read the instructions on the manual for the innovate and it stated further away from the turbo the better so i am having mine right down in the downpipe
Old Dec 30, 2013 | 12:15 AM
higgsy91's Avatar
higgsy91
Well this is a decat pipe bought with the bung pre-welded on. it's for a focus RS and i have all the correct focus RS exhaust turbo bits.. I can't work it out!
Further down the decat pipe there's a bracket almost like it should sit on the block somewhere but it's about 2 inches from even touching the block.
Further down is definately better!
Old Dec 30, 2013 | 08:14 AM
grant_xr's Avatar
grant_xr
My AEM wideband recommends the sensor is fitted at least 18" away from the turbo.
I'll be fitting it at the very end of my downpipe!
Grant
Old Dec 30, 2013 | 08:16 AM
higgsy91's Avatar
higgsy91
Where do you draw the line at too far lol. I have a bung on the FRS flexi where the post-cat sensor would go?
Old Dec 30, 2013 | 11:09 AM
Churtz's Avatar
Churtz
For a wideband it needs to be further than that. If it was a factory standard narrow band it would be fine, as they need heat to operate.
Remember, some tuners will put a wideband up the tailpipe to map a car and get the right readings!!
Matt
Old Dec 30, 2013 | 02:05 PM
Jay,'s Avatar
Jay,
Sponsor
Matt
Which isnt the best as if have a exhaust leak no matter how small it will change the afr
12-18 inches from the turbo is fine
Old Dec 30, 2013 | 02:56 PM
davidfox280585
thats why ive specified while there making my exhaust
it goes on 45 degrees just before it goes under my floorpan
Old Dec 30, 2013 | 03:21 PM
Mk4 Rick's Avatar
Mk4 Rick
Ive seen a fair few on the elbow of the down pipe
Old Dec 30, 2013 | 05:00 PM
JamboRS's Avatar
JamboRS
focus rs 1672
Cheers!
did you buy the stuff off me on ebay?
first thing use the post cat bung for the innovate.ive got my plx afr o2 sensor in that one.would you not need the first one for the lambda sensor anyway?
the adaptor plate has a rubber seal on it iirc. id reuse that and see how it goes.if not carpartsexpress can supply you with a new seal and even use some sealer with it
your stuff was posted today mates so should be with you tomorrow or friday
Old Dec 30, 2013 | 05:43 PM
costina's Avatar
costina
Live long and prosper!!
mines not far from that position you can buy a heatsink thing from burton or ggr.
won't be a problem imo.
Old Jan 1, 2014 | 11:40 AM
stevieturbo's Avatar
stevieturbo
C**t
Just weld a bung in a more suitable location.
Or slightly more obscure...
http://www.ebay.co.uk/itm/Adjustable...item3a83b1b303
Old Jan 1, 2014 | 12:16 PM
studabear's Avatar
studabear
Bit like this.
Old Jan 5, 2014 | 06:46 PM
higgsy91's Avatar
higgsy91
Yeah got all the stuff mate cheers for that
I'm gonna use the post cat bung. Good shout!
Yeah I've seen those before but it takes it too far out of the flow, otherwise it would be perfect.
Originally Posted by studabear
Bit like this.
Yeah that's good, the post cat bung isn't that far from where you have yours in fairness!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
