CR guessing game!
Zetec Turbo Baby Yeahhhh
CR guessing game!
Ok so it's not so much a game.. more a question with an educated guess..
I have a zetec blacktop with JE low comp pistons (9:1 CR on JE website based on standard ZX3 engine ST170 equivalent) and I have a lightly skimmed head and 3 layer MLS focus RS head gasket.
Any ideas?
Good CR?
Cheers!
Any ideas?
Good CR?
Cheers!
how long is a piece of string?
nobody's gonna be able to say without it being a total guess
without knowing actual(not stated on the box) comp ratio before head work
then a light skim could be anything, and can you be 100% sure the head hadn't been touched before?
and is dish/bowl in piston 100% original?
is the combustion chamber in the head 100% original etc
the slightest amount of skimming or work to head or bowl would make a biggish differance to the comp ratio
and the head gaskets can be differant sizes when compressed (differant makes etc)
so there is no way in the world that anybody could possibly guess the comp ratio without having some accurate numbers to work with
The pistons are brand new JE pistons made for the US Spec Zetec. Which would give you a 9:1 CR. Difference with mine is it has the FRS head gasket and a light skim.
If its in pieces measure it correctly and don't guess! Gonna be a chocolate teapot if the head has been skimmed enough to bring it up to a standard c/r.
Dont suppose you know a good thread on how to do this do you? Guy at the garage was going on about filling the chamber up with liquid and all sorts. It's just i have these pistons, which don't make measuring very simple..
need to agree about just doing it right
measure it up properly, just google it and it'll show you how to measure to area and calculate the volumes against each other and work out the comp ratio
do you actualy need to know the static comp ratio? or are you just wanting to know what is?
Cheers, basically i've just been reading up and i basically didn't want to run the risk or too much compression.
I mean it's designed for US spec engines which actually normal have a 0.6mm head gasket anyway, so the FRS 1.2mm gasket (IIRC) should be more than sufficient in replacing the lost material from the skim
It's a mystery, in one place i read the RS uses a 1.2mm gasket, another says it's the same 0.6mm gasket from the N/A engines. I just don't wan't do go much higher than 9:1 CR. Is it worth going for the ST170 4 MLS gasket..
So you're saying go with the hg with the least thickness out of the three? Everyone has a different number lol.. I checked Ford's system but it wasn't much help tbh. In fact useless! Anyway I can find out from my Victor reins packaging on the hg what one I have?
Cheers!
Cheers!
Sounds very interesting this.If my 2 litre zetec blacktop cr was 10.0.1 and I fitted a 4 layer st170 head gasket what would I get cr wise.To my knowledge the engine has been untouched.
9:1 is fine for a modern turbo engine, fitting a thicker head gasket will drop the comp ratio slighly,
but make sure your getting the correct info
as some manufacturers give a out the pakage thickness
and others give a compressed thickness
just dont mix up the 2
Some good info here guys thanks. I think I'll stick with the rs gasket. I'm gonna see if I can find out the thickness of it and maybe take a crack at working out the CR too. I mean how much difference can a head gasket make anyway (here comes the attacks)
kinda sumfin like that, but its also to do with ignition tables
higher CR will make the car more responsive off boost and be less laggy
so more modern set ups usualy go in favour of that as it makes the car nicer to use around town etc
So I'll be running roughly 9.5:1 seems a little high, guess I'll have to cut back on the boost a bit! I fitted the head last night and noticed with those pistons (when I was timing it 180° out somehow??) That the valve cut outs seem to have made it a non interference fit. Result!
Take it too an engine builder and pay for them to cc and test it to be 100% that you have the correct cr
No point building it first and finding out later it's wrong
I bet they would only charge an hours labour too
If it is high you could as they do on the karlos g budget route and fit upto a 1.8mm frs head gasket
But having not built it up any decent engine builder can machine your pistons and recheck the clearence while there
Wayne at wpe (wacky performance engines) did this for me once as I had an engine that the compression was way too high but had accrulites in it
He charged £200 to machine it from 13-0-1 too 11-5-1 and built the engine and redone the head chambers and valve pockets
But I had too supply gaskets and bolts
The Enigma
12-09-2015 10:12 PM
