ford ranger 2wd rear wheel bearing
Hello people!
Im trying to fix my mates 2007 ford ranger 2wd pick up!
The wheel bearing is knackered! I have got the whole shaft out but cant remove the bearing casing / abs ring.
How do I get it off?
The way i do them is to cut the old one off and put the new bearing in the oven but on a very low heat just to warm it up a bit then gently tap it back down with a copper hammer or if your lucky put it in a press. Sounds daft but its the only way to get them back on the shaft.
