Supra diff fitting (MK kit) problems...
Old Nov 9, 2013 | 06:24 PM
peteh's Avatar
peteh
Default Supra diff fitting (MK kit) problems...
Hi lads, I just wondered if anybody else was having as much ballache as me trying to fit their supra diff into their cosworth, as its started to really annoy me now.
Just wanted to make it known this hasn’t anything to do with the kit I used which was MK’s kit that I brought a while ago, as what I can see it’s a great quality kit.
Ok first of started mocking up the bits and found this –
Then found the new stud hidden at the bottom of the box, DOH!
But the back black bracket still wouldn’t fit flush so I had to file off four of the rear fins as shown in this picture with the slight different colour.
Today on my only day off I attempted to fit in the rear hoop and found another bloody problem, after working out how the side brackets attach, well I think I have, is this right?
So I managed to get one side of the front of the diff fitted but when I tried to put the other side in, it was 5mm short, in the pic it isn’t very clear but the brass part should be inline with the black part at the top /
After for the third time taking it apart, I noticed it’s the hoop that stopping the diff move forward as shown in these pics with the rubbage on the freshly powder coated hop, grr and the diff casing…
So I left it like this as I was pretty fed up.
So what do people think?
Anybody else had this trouble?
Should I grind some off the casing or bend the hop to make it fit?
I take it it’s the diff as the beam had a normal 7.5in in before no problem.
Or what ive seen people fit them while the hoop is still on the car, would this make a difference cause you can drop the rear down?
Do they fit level once fitted?
Old Nov 9, 2013 | 07:24 PM
BRAMMER's Avatar
BRAMMER
You need the whole beam in the car before you fit the diff, well it's the easiest way as you need to pry the diff down to tighten the front two diff mount bolts as they sit directly over the top of the two countersunk bolts (make sure they are proper flush too as they touch the diff mount bolts.
Your second to last picture, just above the brass coloured insert the casting thats 90 degree anticlockwise has to be cut off as it will fowl the exhaust system - most do both sides
Don't worry these are tight as fuck to get in, i had to shave the starting threads on the top right silver bolt as it was just a couple of mm out of line but caused massive issues and purely wouldn't go in.
Old Nov 9, 2013 | 07:38 PM
MK MOTORSPORT's Avatar
MK MOTORSPORT
hi
we have been noticing that there can be a lot of differences in the diffs ,ie the fins and lugs etc ,so it can be a case of trimming fins and lugs etc on the diff
also leave everything loose until you have all the bolts etc started then tighten all bolts a bit at a time ,this kit was done as a bolt in kit which it is but can be a pain ,as were trying to fit something that is bigger than standard into the beam,it had to be in this position for drive shaft align and prop position ,so just take your time and have patience as there are lots of people how have them fitted so they do go in,plus people who are having there beams powdercoated seem to forget this can add 2/3 mm on faces and holes etc and looking at yours you haven cleaned it off faces or out of holes
mark
Old Nov 9, 2013 | 07:48 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Diff casings do vary as I have two here and the rear covers are different in fin design.
Stick the kit up for sale mate....I need one lol
Steve
Old Nov 9, 2013 | 07:53 PM
BRAMMER's Avatar
BRAMMER
I think most have to shave the rear case fins, i'd take marks advice and clean every hole up as i said above i was a couple of mm out and believe me it only sounds a bit but it just wouldn't bit so there's modding to do but is expected due to the mass variation in diff casings
Ade500's Avatar
Ade500
Fixing Fords
Yep I agree the beam in the car is the way, I had to trim the side of the diff to clear my beam.
I think the castings vary a lot as my rear case cleared the Mk mount by a few mm, and my mates cleared on the back and the side
Mine fitted all loose first then did it all up tight, positioned the diff to body mount, pinched with the two bolts you can still get to. Then dropped the diff back down and tightened the two that you can't get at ( front two ) then bolted the diff back up and bolt the diff mount up all loose, then tighten.
I have had my motorsport development diff mount counter sunk ( front bolts only ) as I only had 1 or 2mm clearance and didn't want the hassle of taking it out later if it did touch.
Old Nov 9, 2013 | 07:57 PM
BRAMMER's Avatar
BRAMMER
Thats a good idea with the diff mount as mine was completely touching when i fitted so a countersunk bolt would make all the difference in fitting i think - is their enough material in there to do it so the bolt sits flush or not?
Old Nov 9, 2013 | 08:06 PM
Ade500's Avatar
Ade500
Fixing Fords
Yeah pretty much the same as the top Mk plate, its quite thick alloy it is about 1mm proud done up . It's left about 5mm between there now.
Old Nov 9, 2013 | 08:43 PM
peteh's Avatar
peteh
Arh lads, your all legends!!!
Good point bout cap head bolts on the diff mount, hadn't thought about the part yet, lol
So the second and third last pic, think it be better to take off the lip on the hoop or take a little off the diff casing? I won't go into the actual diff champer will I? It feels pretty solid, ie just part of the casing.
And thanks mark for the heads up on cleaning off the paint.
Old Nov 9, 2013 | 08:51 PM
bigluke200's Avatar
bigluke200
Yep.. Mine was a pig as well.
Fin shaving, exhaust re-routing etc etc. Had to bin the ARB on the 3dr as well. (TS kit)
Such a tight squeeze in the end!
Have you had the diff rebuilt mate? Mine was shagged . It's off being rebuilt at the mo.
Old Nov 9, 2013 | 08:59 PM
peteh's Avatar
peteh
Oh yes, bara had mine, needed new bearings, seals etc etc
Big bill (
Old Nov 9, 2013 | 09:00 PM
scoooby slayer's Avatar
scoooby slayer
good call most of them will be well worn out by now probably.
Old Nov 9, 2013 | 09:14 PM
Ade500's Avatar
Ade500
Fixing Fords
So the second and third last pic, think it be better to take off the lip on the hoop or take a little off the diff casing? I won't go into the actual diff champer will I? .
I will get a pic for you mate, its the diff I ground off to clear the beam, then the diff moves forward fine to the bolt holes.
I was gonna see how mine goes as I fancy a 3.9 anyway and I have got to run in the new engine anyway then rebuild my fave with the weir products.
Old Nov 10, 2013 | 08:14 AM
peteh's Avatar
peteh
cheers mate, ill await the pic before i get my grinder out, lol
Old Nov 10, 2013 | 08:29 AM
MK MOTORSPORT
if anyone is having trouble sourcing a diff or fitting a kit speak to cochyn ,he was the one that started all this off so with out him this wouldnt be happening,the kit is very easy to fit in my opinion just a bit of tweeking on the diff
thanks mark
Old Nov 10, 2013 | 08:34 AM
peteh's Avatar
peteh
thanks mark
so im best to take abit off the diff mark not the hoop mounting plates?
as mark said 'cochyn' actually emailed me shortly after posting this, thought who the f@k is that, then realised, doh.
so if anyone wants his email, pm me.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Chas
Sep 21, 2015 08:57 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Gadget
Aug 13, 2015 08:19 PM
COLEYST200
Aug 3, 2015 08:55 AM
