Swirl pot lift pump ?
i use a 044 to feed my swirl pot, this is the pump harvey gibbs said was needed , i then run 2 x 044s to feed my fuel rail with a return back to the swirl pot.
i dont no what power your running so this is only a guide of what i use.
thanks steven
thanks steven
unless your running big power the std pump is fine for a lift pump, it only has to half fill the swilr pot the other half is kept full by the return line.
im runing one inbetween the eninge pump and swilr pot and one between the fuel tank and swirl pot.
id run a good pump for a lift pump then.
A Holley red top will be fine , I had one of these on a old lifter set up and the engine was producing over 500 hp , before I had the red top I used a std cozy pump to lift
And on the rollers it was leaning off around the 480/490 mark .
The swirl pot does not need high pressure , as the pump to the engine will give you your fuel pressure .
And as said above any over filling of the swirl pot will just go back into the tank
Think auto sell the red tops and there not that pricey new .
Wye Valley Hardcore
Live long and prosper!!
I think he means a Facet Red Top. That's what I'm using on my set up as a lift pump. I know when I worked it out, a single Facet, feeding a 1litre swirl pot, supplying a Bosch 979 was ok for my 300-320 bhp. Not sure if a single Facet will supply over 400 though. You'd have to work it out.
Only if the return is fed into the swirl pot too
I used a holley blue pump with return back to swirlpot with no issues running around 330bhp
Holley pump , not a facet
SMILER258
28-09-2015 09:04 AM
