106 GTi Valve Springs into Silvertop Head Help
#41
Zetec Turbo Baby Yeahhhh
Found it.. XR2 Wishy also said good for 300-350
#44
Get the retainers too if you're going blacktop. http://www.ebay.co.uk/itm/Peugeot-10...item338243a62a
#47
#48
Not Crazy, just Unwell
#49
#50
I know! I've said it many a time myself
It needs to be done in time for York so I've got a an ultimate deadline for June. But that's for the complete car lol
#52
#53
Go for a decent set of multi-valve compresssors. Machine Mart was where i went. http://www.machinemart.co.uk/shop/pr...ing+compressor
#54
Yeah about an hour for a straight swap but once the head is off you may as well lap the valves again. It's taken me nearly 2 hours to do a good job on lapping all the valves. Really satisfying once it's done! Go for a decent set of multi-valve compresssors. Machine Mart was where i went. http://www.machinemart.co.uk/shop/pr...ing+compressor
#57
I thought you only had to Lapp new valves and not the same ones as they are already bedded in?
#63
#64
Balls Deep!
I've also been told (but never tried it) that you can shim (2mm or 3mm washers IIRC) the stock valve springs to increase pressure a little, this could be another option for people wanting a medium power budget build.
#65
I've not mate no, most of my builds seem to be either low budget low power which need nothing doing to the head or ST170/black-top based builds and so I use the springs from the ST170 head.
On a side note.. as you have done budget builds, i'm going to use the stock 1.8/2.0 manifold, rail, regulator, throttle body but FRS injectors. Would i encounter any running problems with this setup? I'm going to use a cossie brown IAT sensor on the boost pipe rather than the FRS elbow too.
#67
Would you advise to install the ECU while the engine is in or out of the car?
#69
#71
#72
Well my source was a girl that i was seeing for a bit.. so.. can't really go that route for you mate lol.
Although, you only need the shims for the inlet side technically, i did both sides because i had enough, but it really isn't important to have them on the exhaust. You could even leave the standard zetec springs in on that side if you wanted..
But anyway i think i have around 8 left over...
#74
just a heads up, you actually want to pay more attention to the exhaust valves more than inlet. I have uprated singles with shims under the ex springs.
plus ian howels got the shims if you're after a set.
#79
#80
someone send me some shims and i will get them made up from a local who is great
made my caliper carrier spacers for 4x4 cossie brakes on a mk3 fiesta for £10
drilled and helicoiled my inlet for custom fuel rail and fitted it all up with everything £12
and made a custom charge carrier for my old s1 with swaged ends and sensor outlets for £40
hes brilliant, his company is called spot on throttle cables........
so as the name he can make custom throttle set ups too
