T34 power level with .48/.55/.63 housings?
yes i have tried to search, but not successfully!
basically im after the max power outputs for a T34 with different rear housings on.
T34.48 = ?bhp ?lbft
T34.55 = ?bhp ?lbft
T34.63 = 400bhp? ?lbft
cheers for any input.
considering making one fit my impreza lol
T34.48 = ?bhp ?lbft
T34.55 = ?bhp ?lbft
Well Matt saw 404bhp on his with similar torque on a .48, but you'll hear a lot of folks say that's unrealistic, but tbf he had it dyno'd on 3 different RRs , again, how long it would last at that though is another matter.
So I'd say for safety and this is only my guessing and I'm no tuner but have had all three, lol
.48 = 360 with similar torque, great road car, ( again, can do more with head work cam etc)
.55 = 360-370
63= 380=390 again all can/ could do more but I'd always opt for safety , 30-32 psi peak.
If you want ultimate punch imo go .48
.55 = 360-370
Ye and Mat was running a lot of boost (2.6 bar iirc?)
Are maram shafts still readily available though?
I see, gotta love anti lag on a cossie though, if ever the day comes, its on the Łto do" list"
Ben
Surely the numbers would be different on a different engine? Or am I looking at it from a wrong point of view
I'm ditching my perfectly good t34 with .55 for a tony turbo systems t36 with .55 housing for the plan to hit the magic 400 (combine with one of his inlet cams). I'm worried the t34 would be cacking itself at 400bhp, and want some - ie as much as can be expected from a cossie - reliability!
Ben
Ben
alan Jeffery has had some very good results using a T34 on a EJ20 engine...
I should never have sold my near new T34/63 with 247 mar-m shaft
although there might be a slight delay in making the impreza faster lol.... I think I have broke the gearbox while running a bit late for work this morning lol.
I tested it on the way home with a few (about 5) hard launches and although it still works, im sure its making more noise than it was yesterday
Mine's on a .48 and greens (for now). 300 at the wheels at MSD, recommended I install Siemens 55's, L8, loom & pump re-wire for more, reliable, power.
Mid range punch is fantastic.
why a moron?
I was seeing if it was going to break properly pmsl
if the worst happens, I will just have to get the bike out and cycle to work more (try to do once a week at least, 10miles each way) was supposed to cycle this morning but had a shit nights sleep, then over slept... hence 'smashing the granny out of it'
but tbh, its a fucking rally car (almost) lol, and I don't fanny about in cars really, they are used for what they are built for.
anyway, the box has issues, so its only a matter of time lol
why? because I cant remember lol
http://www.ebay.co.uk/itm/Escort-Cos...item2a312db8ac
mark
Mine was 400 miles old and i paid something like Ł400 for it as the seller didnt realise what it was.
That one from ebay will need a new compressor housing tho as it has a restrictor fitted.
Also for the impreza, should i buy a new turbo ill be looking now at a vf43 with ported exhaust housing.
They are quite a bit newer and better designed than the old garrett stuff, but maybe not quite as tough...
Is there a big difference on the peak torque made by T34.48 and T34.55, given that same engine and boost level is used? Bigger exh. housing will surely give noticeable bump in bhp and smaller exh. housing will give more torque (and hp) in lower revs but is it really worthwhile to go .55 instead of .48 if (midrange) torque is importance?
I wouldn't want to chase numbers and peak hp, so that's why I'm looking for these smaller T34's. Is there any price difference beetween T34.48 and T34.55?
a bigger housing wont feel as punchy but it will be faster in the real world, a t3/t34 on a 0.48 will fall on its face top revs badly ime ive had both on saphs. does anyone have any comparable dyno plots to show the gains/losses ?
as an example I have a plot from a 2.6 with a gt40 going from a 0.84 a/r upto a 1.06 a/r at the same boost and the difference was huge !
that gtr didn't feel as punchy low down but it was faster, a lot faster ie 30 - 130 was about 1.5 seconds faster !
I don't see the importance of the big punchy feel in mid revs, whats the use of that if it falls on its arse above 5000 rpm imo, when pushing hard through the gears you will constantly be above 5000 rpm and the motor is being strangled to death.
You are right about the bigger turbo making car faster on straight line as you will be using revs from 4000 to redline where the punch is required. However I've noticted that I rarely do hard accelerations on highways, I've been driving down smaller roads with lower gears/revs so I could use some torque low down. Here's some dynographs I found from this forum, quite a differences on torque levels 3000ish rpm.
T34.48
T34.48
T3?
T34.63 (much lag, bad map?)
T34.48
T34.48
T3?
Russ Payne
25-09-2015 08:29 PM
