Bought an ST-2 with a few faults. what exhaust av i got. Advice
Old 25-08-2013, 07:17 PM
  #41
ESCORT-NUT-2012
ESCORT-NUT-2012's Avatar
how much did it go for?
Old 25-08-2013, 07:19 PM
  #42
Jay,
Sponsor
Jay,'s Avatar
Originally Posted by scoobykilla123
2k lol that's not cheap that's stolen
been offered 1 asbo and 2 black 07's in the last 3 months ranging from a nackered bottom end noisy head and suspect split liner all foe under 2k each mate
Old 25-08-2013, 07:20 PM
  #43
leedsrhinos126
leedsrhinos126's Avatar
eBay mate loads. He's just attached the rear silencers and the racecat to the middle pipe. That's a mongoose I'd say then, remove that big box it'll be loud. Mines proper loud and its just a decat but remapped lol
Forgot to say mines been remapped, induction, exhaust apparently has a bigger turbo uprated clutch. 289bhp
  #44
scoobykilla123
scoobykilla123's Avatar
Mongoose on eBay 281120626849
Old 25-08-2013, 07:21 PM
  #45
GVK.
GVK.'s Avatar
Jay, it's a U code, U codes are module communication network codes, how many more times do I need to post this?
  #46
scoobykilla123
Yeah but engine work oosh 2k for a block.
Old 25-08-2013, 07:22 PM
  #47
chris cdti
chris cdti's Avatar
Bigger turbo would be well over 300bhp
  #48
scoobykilla123
Printout? What's it boosting on the dash gauge?
Old 25-08-2013, 07:23 PM
  #49
chris cdti
chris cdti's Avatar
Bargain!
  #50
scoobykilla123
The standard turbo will do 300 easy and more pumaspeed can get around 335 now from them.
Old 25-08-2013, 07:25 PM
  #51
leedsrhinos126
What should it show the gauge?
Old 25-08-2013, 07:26 PM
  #52
chris cdti
chris cdti's Avatar
I know having had one at 288bhp on a standard turbo , but if the op's car had been mapped with "a bigger turbo" it should be putting out more than 289bhp.
Old 25-08-2013, 07:27 PM
  #53
scoobykilla123
Agree, bet its not lol.
  #54
chris cdti
chris cdti's Avatar
Standard will hold at half way. Mapped should be into the red area ish at 1.2bar
  #55
scoobykilla123
Well mines mapped and the gauge goes all the way up and stays there lol standard I don't think they do. I need to fit a proper gauge lol
Old 25-08-2013, 07:28 PM
  #56
leedsrhinos126
Thats why i said "apparently" got a bigger turbo remember this is the owner that told me the car had zero problems.
  #57
Jay,
Sponsor
Jay,'s Avatar
Which leads to 3 things imo
1/ speed sensor
2/ ABS CONTROL UNIT
3/ ECU
Old 25-08-2013, 07:30 PM
  #58
leedsrhinos126
Mine does, just looked at the gauge it's 1.2 bar and it stays there, i went for a boosting session earlier. Very quick car goes like stink
Old 25-08-2013, 07:31 PM
  #59
Jay,
Sponsor
Jay,'s Avatar
Bargain!
Not Really 1000-1500 engine if required and time isnt free even my own so another 1k 1.5k labour inc belts sundries ect your at the retail so not cheap when you can by one save the grief
Old 25-08-2013, 07:33 PM
  #60
leedsrhinos126
Ł1000 lost out on Ł600 in 4 weeks
  #61
scoobykilla123
That was my point though when you said 2k. Your not getting a car like he's got for 2k even with those problems.
Old 25-08-2013, 07:36 PM
  #62
chris cdti
chris cdti's Avatar
Depends if you go rs engine route and work off the clock and keep it as your own car
Old 25-08-2013, 07:37 PM
  #63
scoobykilla123
Isn't it er the same engine.?
Old 25-08-2013, 07:39 PM
  #64
chris cdti
chris cdti's Avatar
Bottom end etc is slightly different, lower compression ratio for one, but that's for another thread.
Old 25-08-2013, 07:51 PM
  #65
leedsrhinos126
These engines aren't that bad on fuel to be honest, anyone else think this?
I put Ł40 in and got 124 miles and said 43 miles range left.
That's driving most places in a higher gear but quite alot of boosting
My sierra 2.0 8v i get 137-150 miles from Ł50 driving like a twat. 308 miles to a full 65L tank all motorway
Old 25-08-2013, 07:56 PM
  #66
GVK.
GVK.'s Avatar
1/ speed sensor
2/ ABS CONTROL UNIT
3/ ECU
OK, how can I explain without seeming to be a clever cunt know all.
Simple fact is, on Ford IDS (the pukka Ford diagnostic tool) when ever there is a U code it states something like "Modules should never be replaced on there being just a U code alone" (or words to that effect)
If it was a wheel speed sensor there would be a specific C (chassis) code eg : Cxxxx relevant to a faulty sensor/wiring/tone wheel etc
It could of course be because of a fault in the PCM from a sensor issue as all the systems are linked via can-bus.
Old 25-08-2013, 07:58 PM
  #67
scoobykilla123
Nah I don't find it greedy. Compared to the 6 Mps we had before it it's like owning a derv lol
Old 25-08-2013, 07:59 PM
  #68
studabear
studabear's Avatar
consumption may increase in the winter.
Old 25-08-2013, 08:00 PM
  #69
chris cdti
chris cdti's Avatar
I used to get 220-260 to a tank around town and 300 on a run
Old 25-08-2013, 08:03 PM
  #70
chris cdti
chris cdti's Avatar
Vauxhall s are the same with their no canbus communication codes, they get set if the controller does not send a signal back in 0.06s even though they are ok.
Old 25-08-2013, 08:18 PM
  #71
GVK.
GVK.'s Avatar
As it's got a noisy wheel bearing, it may have effect on the ABS too (TSB 56/2011)
"Should a customer express concern that the brake system warning lamp is illuminated in the instrument cluster and DTC C1141 and/or C1142 are stored in the ABS Module, the probable cause is a missing ABS signal due to front bearing movement as a result of insufficient front wheel bearing fit in the wheel knuckle.
The diagnostics in FordEtis IDS already include this as test but have been revised to include reference to this Service Instruction and should be followed where available.
To rectify this concern, a new front wheel hub should be installed. To prevent the bearing to move in the wheel knuckle bore, the wheel hub should be fixed with sealant.
Parts - Wheel Hub (including bearing) finis 1 471 854
Sealant (Thread Locking HS) (5 ml; sufficient for two wheel hubs) finis 1 461 313
Old 25-08-2013, 08:37 PM
  #72
leedsrhinos126
Cheers bud
Old 25-08-2013, 08:44 PM
  #73
studabear
studabear's Avatar
Can you explain where the sealant goes? I thought these are gen2 type bearings, just wondering if I'm missing something?
Old 25-08-2013, 08:47 PM
  #74
GVK.
GVK.'s Avatar
On the TSB illustration it shows the sealant being applied on the outside of the bearing case.
Old 25-08-2013, 08:56 PM
  #75
studabear
studabear's Avatar
Thanks,handy to know.
Old 25-08-2013, 10:59 PM
  #76
1.9 xr2 on 40's
st170 breaking
1.9 xr2 on 40's's Avatar
Pm me next time matey I've got a low miles engine sat in my way
ŁŁ for you too of course
Old 25-08-2013, 11:20 PM
  #77
Jay,
Sponsor
Jay,'s Avatar
Think 1 black one is still sat still ill make a call tomorrow
Old 26-08-2013, 05:18 PM
  #78
leedsrhinos126
Before
After
Had a look behind the seats for the first time today and found this mess about with the amp and FOOK me this seems to be a serious bit of kit?
Old 26-08-2013, 06:38 PM
  #79
scoobykilla123
Go on eBay and get yourself a battery cover and ecu cover for the one next to the big orange intake pipe.
Bailes1992
03-09-2015 02:17 PM
cossie_chris
39
31-08-2015 11:58 AM
YODI
30-08-2015 01:12 PM
track.focus'd
12-08-2015 05:53 PM
ray barker
07-08-2015 09:00 AM
Quick Reply: Bought an ST-2 with a few faults. what exhaust av i got. Advice
