Any ideas for removing cement splashes off paint?
Old 10-08-2013 | 03:54 PM
p.cressie's Avatar
p.cressie
Default Any ideas for removing cement splashes off paint?
As title. Accidently got some on the Mondeo the other night and didn't realise till the next day when it was dry. Tried pressure washing it off, but that didn't really touch it. Anybody any ideas?
Old 10-08-2013 | 04:14 PM
louis_2012's Avatar
louis_2012
Try detailing clay
Old 10-08-2013 | 05:14 PM
pud s1's Avatar
pud s1
I used wonder wheels .wheel cleaner on mine worked a treat .but don't forget to give it a good wash after
Old 10-08-2013 | 05:20 PM
Stoka's Avatar
Stoka
I had this shit happen on my RR a good few years ago, what I did was use 50/50(ish) fairy liquid and water and keep it wet for a good while, something like a sponge kept wet and held ontop of it, then just blast it with a pressure washer at close range, for godsake dont rub it at all.
good luck
Paul
Old 10-08-2013 | 10:25 PM
BM08's Avatar
BM08
Maybe tar/glue remover? Give it a good soaking and leave it for abit, then get a power washer or strong jet of water to blast it off. Could help it off by using a credit card to slice under it?
Old 10-08-2013 | 10:50 PM
neil andeRSon's Avatar
neil andeRSon
We got stuff from a local cement mixing place for cleaning up a car that had cement splashed up both sides. It reacted with the cement an it fizzed off. Didn't touch the tar that was on it. Can't remember what it was called tho. Could possibly find out and let you know at the start of the wk tho?
Old 11-08-2013 | 01:29 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
I've had to flick it off by hand and maybe a little card poking but it left marks where it has been
Was my work van so didn't really matter but after 3 years the bits I left have fallen off the van somehow but its been in the hands of someone else
Old 11-08-2013 | 01:50 PM
uruk hai's Avatar
uruk hai
You could try this ?
http://www.elitecarcare.co.uk/autosm...r-5-litres.php
Old 11-08-2013 | 06:34 PM
p.cressie's Avatar
p.cressie
Cheers for the reply's, gives us a few things to try. Cossie690 that would be great if you could.
Old 11-08-2013 | 09:42 PM
humey's Avatar
humey
I deliver ready mix concrete for a living, we use hydrochloric acid to clean the cement dust and hardened concrete off the wagons, its the only stuff that touches cement, if you get some dilute it really well 1st, wear eye and impervious gloves when handling it, the cement will just fizz off, id use a soft brush apply then rinse off soapy water.
Old 11-08-2013 | 10:04 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
crow bar and lump hammer. give it a good whack if its stubborn. than finish off with some filler, primer and paint. it will look lovely
Old 12-08-2013 | 07:40 AM
neil andeRSon
Sounds like the stuff we used. We weren't told what it was tho
Old 12-08-2013 | 11:02 AM
marco polo's Avatar
marco polo
use brick acid or patio cleaner that will remove it you will have to water it down tho ..it wont harm the paint thats the main thing
Old 12-08-2013 | 11:08 AM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
^^^^^ Exactly what I was going to say
muffster
13
03-09-2015 10:40 PM
29-08-2015 09:16 PM
john_3.0s
16-08-2015 07:40 PM
