double sided foam adhesive removal
Got a transit bonnet where the double sided foam adhesive between the vent and bonnet is still stuck to the bonnet,other than heat gun & patience what other methods can be employed to remove the bloody stuff
thanks in advance
thanks in advance
![](https://passionford.com/forum/images/smilies/roi.gif)
try some "goo gone" i had this issue once and it worked a treat
http://www.axminster.co.uk/goo-gone-...fs3htaodadgala
in the garage
Plastic scraper to get most of the foam off then abit of tar and glue remover. That's how I get old number plate pads off at work mate. Let it soak in a few minutes then a little rub and its gone.
This is designed for it - i've used mine on the side mouldings - removing the old seal from the rubber grill
http://www.machinemart.co.uk/shop/pr...isc-with-shank
Obviously if you hold it in one position for 1/2hr it might, but a lot of bodyshops use it for taking off side skirt/spolier and badge backing adhesives.
Si B
12-09-2015 06:49 AM
grishenko45
09-09-2015 12:58 PM
