MISSFIRE
Old Aug 4, 2013 | 04:43 PM
Ellis1990's Avatar
Ellis1990
Default MISSFIRE
my ford fiesta 1.25 has developed a missfire, its due new leads and plugs but i have had the coilpack on for ages. what are good parts to use? is it worth putting expensive stuff on or should i just fit standard?
Old Aug 4, 2013 | 04:53 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Any electricals I always say genuine, they do suffer with coil packs, if you got any testing gear (multimeter) check resistance across 1+4 and 2+3 should be 11k give or take and 1+3 and 2+4 should be just about readable 2-8ohms
Old Aug 4, 2013 | 05:33 PM
Ellis1990's Avatar
Ellis1990
thanks pal, ill have a look at work tomorow, i was looking at that puma speed MSD coil. do you think its worth it or should i just use a ford one.
Old Aug 4, 2013 | 05:46 PM
GVK.'s Avatar
GVK.
They're more expensive, but use a genuine Ford coil when possible.
Plugs if not genuine, I like NGK in anything, never had a problem with them.
Old Aug 4, 2013 | 05:51 PM
Plugs leads and coil pack.I bought a coil pack for the wifes old mk5 fiesta and it cost about 25quid.It was spot on and never caused any trouble.
Old Aug 4, 2013 | 07:12 PM
gingerturbo
The puma speed coil is a good idea but would be point if 1. The fault isn't the coil pack and 2. Your replacing the engine
Old Aug 4, 2013 | 08:47 PM
Ellis1990's Avatar
Ellis1990
just checked it is the coilpack, missing on number 4. how much are ford ones?
Old Aug 5, 2013 | 09:39 AM
martysmartie's Avatar
martysmartie
What makes you think that? If its not firing on that cylinder, it may be a plug or a lead, usually it would be missing on two cylinders, in your case number 1. It's worth swapping a plug and lead to see of the problems persists.
Martin
Old Aug 5, 2013 | 10:47 PM
Ellis1990's Avatar
Ellis1990
Martin
thats what i did, runes like a gooden now.
fish6634
Ford KA
Aug 2, 2015 01:02 PM
ginger1979
Jul 31, 2015 09:56 PM
Ginge !
23
May 28, 2005 01:06 PM
FletchCossie
Jul 19, 2004 08:17 PM
AlexD
Feb 26, 2004 08:59 AM
