Can someone identify this Hose please.
I have an early red top J plate 1991 sapph and that is the correct hose for the thermostat housing to pipe along bottom of radiator
The only thing I can think of is.......on yours, the pipe that runs along the bottom of the radiator is it straight or an L shape? as the L shape is off a green top later saph and your may have been changed at some point
I had this problem when I bought that pipe of autospecialists, they listed as 91> when it should have been 2wd or 4wd
I assure you though the hose is correct![](https://passionford.com/forum/images/smilies/smile012.gif)
http://www.autospecialists.co.uk/Sap...oduct-566.html
http://www.autospecialists.co.uk/3dr...oduct-481.html
if so phone them up and explain the situation and they will be more than happy to help.
i had a problem with a boost hose they sent me, phoned them up and the sent me the correct one out straight away
i had the L shape pipe on mine with the standard radiator which i have now got rid of and have bought an alloy rad. is there any reason why i cant use the straight pipe along the bottom of the rad? as the lower hose from the header tank goes straight down now, obviously to join a straight lower rad pipe.
I'm sure it was changed for clearance when running multi ribbed belts
Russ Payne
25-09-2015 08:29 PM
