Gutted.... might have just found the reason my race car didn't work in 2012!
My 2012 racing season was ruined by an on boost missfire and water loss that I just couldn't find ( I presumed the coolent was pressuring up when warm) the engine is out for an expensive rebuild to sort it....
Tonight whilst cleaning the water stains off the header tank I've only just gone and found a crack in the underside of it Argh!!!!!!!
when racing by the time I got into parc ferme and got the bonnet open the water had dried up on the hot tank leaving just stains but around the coil / map sensor was still wet..
![Name: null_zpse32bf83c.jpg
Size: 51.3 KB](https://passionford.com/forum/attachments/general-car-related-discussion/90019d1501528187-gutted-might-have-just-found-the-reason-my-race-car-didn-t-work-in-2012-null_zpse32bf83c.jpg)
steve
steve
At a guess you probably had the suspected head gasket /coolant pressurisation problem as well Steve because any garage you took it to with a coolant leak will have done the bare minimum of a cooling system pressure test to 30psi so I can only assume that header tank doesnt leak until above that pressure or they would have found it? The only way to exceed that pressure is an engine problem.
That said, the over pressure cap should have been venting long before then and you would maybe have noticed that it WASNT coming out of the cap? (Stains/antifreeze etc on top and sides?)
Testing the future
you could have loaded it up on a rolling road with the bonnet open and looked for the leak but hindsight is a wonderful thing to say what you could have or should have done
the engine isn't apart yet but the head will be off this week so we may see something then
steve
Testing the future
Oh well, it's a positive thing you found the crack so don't look at it from the negative aspect of the engine being taken out and time wasted etc. You could've recon'd it and still had a sinister water loss issue which would've bee a right pain in the ass.
Swapping the HG is probably a good preventative maintenance measure, so again i wouldn't be too pissed off about it, but it'd be good if it was all free!
track.focus'd
12-08-2015 05:53 PM
Versus_Creations
24
05-08-2015 09:32 PM
