what power have u had out of a 205 block?
Old 21-06-2013 | 10:29 PM
  #41
MrC's Avatar
MrC
Rs500 205 block Adam
Old 21-06-2013 | 10:32 PM
  #42
Turbosystems's Avatar
Turbosystems
Super Moderator
there are more than 2 205 block castings
The rs500 was unique
Old 21-06-2013 | 10:33 PM
  #43
adam151082's Avatar
adam151082
Good cos thats what ive got. I was worryed my stage 1 was going to crack with the massive power
Old 21-06-2013 | 10:35 PM
  #44
MrC's Avatar
MrC
I seem to remember hearing this, wasn't it the really early 3drs that had a slightly different one and also the head was slightly different in the older 3drs aswell??
Old 21-06-2013 | 11:17 PM
  #45
Alps Pacino's Avatar
Alps Pacino
My genuine rs500 block cracked all the way down one side at around 370bhp. I honestly think its luck of the draw with the blocks as this was discussed a few years back and there were loads of people with falled 200 blocks aswell.
Old 22-06-2013 | 09:17 AM
  #46
2wd saff cos @ stage 3's Avatar
Originally Posted by scoooby slayer
ive run stage 3 twice on 205s.
steve was running big power with no issues, spend the money elsewhere is my advice.
this is what I think I will be doing, thanks
Old 22-06-2013 | 09:20 AM
  #47
Originally Posted by Rod-Tarry
My advice is dont risk it, you are asking the question because you have heard of failures using a 205 Block. Its easy for others to suggest you take the risk.
they are also stating failures in 200 blocks, It will annoy me more to spend the money and time getting a 200 block and it break then using a 205 block I all ready have
Old 22-06-2013 | 10:53 AM
  #48
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I can only give advice mate dont give a monkeys nuts if you take it.
Ive only cracked a 200 Block at 900+bhp & had 6 M.A.developments conversions over 500bhp but what would i know about modded Cossies .
Old 22-06-2013 | 05:42 PM
  #49
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
For once I agree with Rod Why the hell would you base an engine build on a 205 block when a stronger block is available relatively cheaply ? The block is the core of the engine, economise elsewhere is my advice.
Old 22-06-2013 | 05:51 PM
  #50
Alps Pacino
is the 200 block that much stronger than the 205 block? I remember this question being asked years ago and loads of people had failed 200 blocks as well as 205 block.
Is it a case of both have limitations but there is less chance of a 200 failing? What are the limitations of both blocks?
Old 22-06-2013 | 06:02 PM
  #51
Martin-Hadland
Yes exactly! There isn't any hard and fast rules as to the limits of each as some people seem to have better luck than others but you can't long stud a 205 block for a start. Its a bit like 4x4 gearboxes, years ago I ran one with 500hp for about 6 months and it was absolutely fine but when it failed I changed it and broke the replacement on the way home! After that I couldn't keep a std box in it for more than a week or so!
Old 22-06-2013 | 06:08 PM
  #52
Alps Pacino
haha yeah I know about the long studding. I think that's why people are reluctant to spend the extra cause it does just seem luck of the draw regards to block failures.
If there was hard evidence that a 200 block could do 500bhp all day long but a 205 WILL fail at anything over 400bhp then I am sure everyone would buy a 200 block for a big power build.
Old 23-06-2013 | 10:58 AM
  #53
rod I didn't mean to sound horrible I apologise if it came across that way, thank you for your input
Old 23-06-2013 | 11:00 AM
  #54
im only asking because, I have a 205 block in the garage now & im not doing a monster bhp build
Old 23-06-2013 | 11:02 AM
  #55
scoooby slayer's Avatar
scoooby slayer
I ran a Turkish on 0.5mm bore with a t4 at 2.2 bar 7800 rpm limit on stock head bolts wrc gasket no problems.
I only did 3k miles in it but they were all give it death miles lol
gcfcos
59
06-10-2015 05:04 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
AJC
01-10-2015 06:47 PM
20/20 vision
29-09-2015 11:27 AM
20/20 vision
28-09-2015 03:03 PM
Quick Reply: what power have u had out of a 205 block?
