what power have u had out of a 205 block?
21-06-2013 | 04:27 PM
One for the cossie ppl here, what bhp have u had out of a 205 block? what bhp are they good for?
Thanks
21-06-2013 | 04:31 PM
442 bhp 380ft/lb for over two years and it ran 400 for many yrs before that, my old Sapph that is.
21-06-2013 | 04:33 PM
wow that's good then, I didn't think they could handle it when u dstart getting near 500hp
21-06-2013 | 04:36 PM
537.9bhp and 451.9lb/ft
Steve
21-06-2013 | 04:37 PM
To be totally honest, if i were going to run that again, or 500 bhp I'd build it from a 200 block i think, but as said some do run 500, i remember Dingy & Brom i think it was running over 500, now whether the blocks shat themselves i don't know, Cossie4i off here too
21-06-2013 | 04:46 PM
I only intend on running stage 3 so 200 block will prob just be a waste of money
21-06-2013 | 04:47 PM
Quote:
Originally Posted by
cossie4i+
Steve
that's some serios horsepower lol
21-06-2013 | 04:48 PM
Upto 400 it'll be fine, stage 3 will be fine (hopefully) i say that because there's ALWAYS that chance
21-06-2013 | 04:49 PM
2wd saff cos @ stage 3
It was fast
Peaked at 2.23bar on the hub dyno and was still holding 2 bar @ 7400rpm it the limiter .
Not so fast now as I missed a gear and over rev'd it playing with a big bike lol
Steve
21-06-2013 | 04:54 PM
Staffi
I totally agree, think I will stick to 205 block with nice pistons and rods
21-06-2013 | 04:56 PM
cossie4i+
It was fast
Steve
I bet that was mental on the dyno
oh dear, what damage?
21-06-2013 | 05:01 PM
No idea, killed at a year ago almost to the day.
Its still in one piece parked next to the 3dr lol
Steve
21-06-2013 | 05:06 PM
Your stock pistons & rods will be fine for what you're after, save your money and buy some good brakes
My cousin's engine was built by steve scott 18 months ago. 205 block. Wrc pistons. Gt30. 83lb siemens. 28psi. Cams etc and lots of headwork. Not sure on power but gotta be 500ish. Gives it death regularly and it still purrs. Stacey
21-06-2013 | 05:09 PM
cossie4i+
Steve
lol u haven't even looked at it
21-06-2013 | 05:11 PM
Staffi
I only have a bare block
so kinda got by pistons and rods lol, don't worry about the brakes I will be buying them as well
21-06-2013 | 05:12 PM
Kirbycossie
wow good to no, thanks for sharing
21-06-2013 | 05:18 PM
Oh, that i didn't know
21-06-2013 | 05:24 PM
Tbh it's the luck of the draw, if it's mapped correctly there's no reason you can't get 500bhp out of a 205, hey even some 200's can't take it.
21-06-2013 | 05:30 PM
Staffi
lol no probs, cos I will be saving money on buying a block, I can put it into buying nice internals
21-06-2013 | 05:31 PM
100% agree with u
21-06-2013 | 05:36 PM
cossie4i+
Steve
What happened Steve?? Did one of cylinders go down or did it stop dead??
21-06-2013 | 06:01 PM
Bottom end has a little rattle lol
Steve
21-06-2013 | 06:25 PM
I ran 473 bhp on mine then added a wizard noz kit and put their 400 bhp jet into the nitrous solenoid it went like fook! And lasted for about 2 years the nitrous twisted the block but was reliable with the 250 solenoid in for many years
21-06-2013 | 06:38 PM
ive run stage 3 twice on 205s.
steve was running big power with no issues, spend the money elsewhere is my advice.
21-06-2013 | 07:08 PM
scoooby slayer
My advice is dont risk it, you are asking the question because you have heard of failures using a 205 Block. Its easy for others to suggest you take the risk.
21-06-2013 | 07:34 PM
We built a customers engine on a 205 at .5mm oversize bore and a greens conversion cracked the bore very shortly after! Luck of the draw I'm afraid
21-06-2013 | 07:37 PM
My 205 cracked down the side at 471bhp/400ftlbs
But lasted well at 405bhp before that
21-06-2013 | 08:17 PM
Is the rs500 blocks any stronger?
21-06-2013 | 08:24 PM
adam151082
yes, much!
21-06-2013 | 08:36 PM
a well built 205 block will outlast a badly built 200 block ,450 bhp is probably getting near its limit but then again it will totally depend how hard its driven lol
21-06-2013 | 09:23 PM
What about liners on a 205 block?? Would strengthen the bores.
It seems the weakpoint is the bores, it happened to ronny on his 200 block, big dirty crack down the middle of the bore, so as said before no one is 100% safe
21-06-2013 | 10:09 PM
Mr c that was a Turkish block, known for their inconsistent cast thickness around the block and it ended up very thin on the bore wall at .5 OS
21-06-2013 | 10:15 PM
there are different types of 205 blocks
21-06-2013 | 10:17 PM
Turbosystems
I think you need to explain a bit better than that my moaning friend
Steve
21-06-2013 | 10:20 PM
plus they all crack in the same places just the 200 wont twist as much the 205 in big power
21-06-2013 | 10:21 PM
I'm aware of the Turkish block, you don't see many about anymore, and yea toner we are talking about the standard 205 block mot the rs500 deritive
21-06-2013 | 10:23 PM
cossie4i+
Steve
why
you're all to tight to buy a proper block
21-06-2013 | 10:26 PM
Turbosystems
why
Hahahaha
Turbosystems
The normal 2wd 205 block
and the RS500 205 block
whats the best block to have 200 or RS500 205?
