snapped the fooking key off
1 Post
please help, the ignition key just snapped off on my escort mk6/7, can i fit a used set of locks and key, havent phoned my local breaker yet, not open again till monday, always the frigging way
I lost keys for my mk6 escort so just burst the steering lock and started it with a secrewdriver or anything that fitted in the switch. It was a pie of shite so it didnt bother me lol. someone steaing it wouldve been doing me a favour lol.
Sorry if its no help but just thought id share!
i dont know about other mk6 escorts but i know with the rs2000 you need the ecu, the immobiliser piece around the ignition barrel and the correct key for it to work if your buying a new set, im pretty sure all mk6 escorts had immobilisers as all the ones ive owned have ranging from 1995-1998 so i dont think a screwdriver will get you started but i think they have a different immobiliser setup to the rs2000 sorry that i cant be of much more help
Oh yeah mine was poss a mk5b and had a td engine with no immobiliser.
if the op still has other part of key he could tape it to the antenna for it immobiliser and use a screwdriver
struggling with reality
ok if you are very careful you can put a dot of superglue on the piece of the key you have and mate the 2 sides together. now hold really still for at least 30 secs. then gently pull out the key. destroy key then get another one cut.
there are several other tricks you can do. I once drilled a small hole in the middle then super glued in some wire to pull a key out! also a braddle type object with the very very end bent to one side can be used to encourage it out too!
pm me if you are based near salford!
Dremmel is your friend! good luck
fords passive anti theft system consists of key reader[round the ignition barrel] immobiliser box [hidden behind the dash] u put the key in the ignition the box reads the chip in the key then disables the immobilisation
NC53
13-09-2015 03:05 PM
