ERST breather system.
DEYTUKURJERBS
As standard, ERST breather sys plugs into the airbox like on Cossies (and most other cars) right?
Anyone got a diagram of the std ERST breather setup, and what changes when using an uprated setup?
Cheeeers
Cheeeers
PassionBMW.com Member
Standard:
Pipe between block and top right of cam cover.
Top Left Cam Cover port into little plastic thing, then goes via big plastic pipe to meterhead. + vacuum tube to inlet
Uprated:
Block goes to bottom port on breather pot.
2 cam cover ports to the breather
And the remaining port on breather (as there is 3) goes to the meterhead.
Uprated:
590 BHP/Ton
Originally Posted by Itsmeagain
And dont the one to the metering head suck oil thru on boost?
Mc5506
05-10-2015 09:57 PM
