Air Con recharging
Moderator
![](https://passionford.com/forum/images/pf_trader.gif)
![](https://passionford.com/forum/images/pf_staff.gif)
My little fez must be out of gas and it just clicks when I turn the A/C on, who's best to test/recharge the system on the high street as not taking it to ford thats for sure, what sort of pricing is it also ?
http://3dautoelectrical.co.uk/contact#
im taking the wifes TT here this afternoon for service and regas for £50
Imperial way trading estate. I'll let you know if any good later this afternoon.
Moderator
sweet thanks for the heads up guys
I have one of those cards, only thing is I take it you need to buy the trigger/guage part as well unless its go it built onto can, which makes its nearly same price as kwik fit etc
Martin
Resident Wrestling Legend
kwik fit have a money back garantee so if the temps don't come down they won't charge you ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
so if you have a hole in the system the vac finds it and doesn't put any gas inside
they also stick in some oil as well which oyu need to lubricate the system
it's not the best set up ever but it's good enough for those times when you've just run out of gas over time
Use a reputable company that will properly leak test the system before recharging, not the usual high st outlets. I am in air con , but not automotive. Anyone can bang some refrigerant in there and not understand whats happening or issues .
Moderator
mate had his done in kwik fit earlier and said they did a good job removing any old stuff and doing test before even trying to refil it and took around 45 mins, so looks the fav at moment
Testing the future
as dojj hints, use a place where you don't pay if it doesn't improve the vent temps. then disconnect every connector and fuse in the system that you can find so that even with a nice full charge the a/c will not actually work ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
as to your mate thinking that they did a good job taking all of the old stuff out before filling it up again - the machine only has one bottle so what you get filled into yours is a mixture of what has come out of everybody elses
I would remove the refrigerant if it didnt work.
Plus the pre checks would show the compressor as not working unless system was completely empty with no pressure, so I wouldnt be recharging anyway.
Moderator
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
