Has anyone fitted a Walbro?
Zetec Turbo Baby Yeahhhh
Hi all, got a fuel pump problem as in the fuel pump is a lot taller than that of the standard one and therefore won't fit in the swirl pot correctly, the lid of the swirl pot also has a shoulder in the hole for the fuel pump which obvisouly now needs to be ground out because it is so much taller...
But anyway, has anyone ever fitted one of these or a deutsch werks or an aeromotive... and modified it to fit as i'm a little stuck.
This is for a ford focus mk1
you cant fix stupid
i fitted a da255 which from what iv read is similar to walbro. it was taller than standard and i had to do some modifying to get it to fit and work. biggest problem i had was not realising i needed special "in tank pipe" to replace the ford parts i could not use. i was shredding pipes in no time. look at my build thread and ive got pics of all i done. not sure if it will help you but take a look and see.
marky_g
15-08-2015 10:43 AM
track.focus'd
12-08-2015 05:53 PM
