Wiring woes...!! Pectel 2 and other problems
Under the car...!
Right chaps.
Ive had a right nightmare with this car for the past week... (dax kit car)
To summarise things, clutch slave failed so I replaced it, I also replaced the alternator with a new one as it was overcharging at about 15.2volts with everything on, and after I had replaced rectifier and regulator in it.
Went to start the car the other day as the sun was out
and nothing. Nada. the car turned over happily but wouldn't start.
The clutch fluid reservoir is in a daft place under the dash and needs unbolting and lifting out to fill it.
I thought I might have pulled a connector out of the wiring loom under the dash. Theres a few spade connectors under there.
After several days of tracing wires and trying to find the problem. I am not better off. I even got a supposedly good local auto electrician out who was totally stumped and knew less than me... (there goes £45)
There is power to the Pectel T2 ecu. There is 12v on the injector wires and ignition wires to the Pectel (Ive got the plug diagram thank god)
but theres no action at the engine
No spark. No fuel. Zip.
Just turns over.
I am seriously getting pissed off with it Anyone got any suggestions?
Should the pectel connector plug have voltage at the pins for injectors and ignition coil? I would have thought the pectel should send the voltage out to them, seeing as it has power from the battery on a different pin??
I am new to standalones
Any help really would be appreciated
Ive read this thread
https://passionford.com/forum/genera...agnostics.html
but cant get descpro working and dont have the bloody base map!! It is a formula ford T2 as Ive had it apart today
Just turns over.
Under the car...!
its getting to the point where if I cant fix it in a week or two, the engines coming out to make way for the new one and Im going to do a complete new loom myself.... not really looking forward to that option though!
Under the car...!
Ive charged the battery on a decent charger and it wont start even whjen its full. Ive also added a battery booster on for later attempts when I have been trying to get it going!
NO, it has not run since I replaced the alternator. But I think this is more coincidence than anything?!
It should run without the alternator (or start at least) and I have actually disconnected the power feed from battery to it and also the warning lamp wire, and its made zip all difference
Turns over, no spark, no fuel, no start!!! aaagh
get a loom made speak to Ahmed Bayjoo or mark at grove can have a loom made making your problem half ! and he is the best for mapping a T2 !
Under the car...!
No priming from fuel pump mate .
how can I check crank sensor please?
Cheers xr4i silver. the loom is good for the ecu . it's the car loom that I need to redo ! as I don't have the base map I can't use desk pro (if I can get it working) to check the t2!!! might have to go mega squirt 3.. Nitemare
At least I'll assume the Pectel does prime the pump on key on as every efi ecu does.
Under the car...!
the problem is that as I dont have the base file and its probably locked, Im not sure if the car would need remapping or what?! If that was the case I will just go balls deep and take the engine out, new wiring loom , the new engine Ive got and new ecu and mapping. But thats a major amount of work and I am moving house in the next few months , getting a better garage so don't really want it in bits before then. In fact thats partly why Im moving house, so I can have more space lol
I still cant see how it can have blown, is there an internal fuse in a T2? i cant see zip thats like a fuse in there. IN fact I cant believe how basic the pcb is...!
Are there any T2 people who can tell me how to fault find on it?
ZETEC TURBO
I don't know how to fault find on the ecu but asfar as i know there isn't any internal fuses in there.
Might be worth checking your cps aswell. I had issues with mine starting when i first built mineaand it was caused by the starter motor causing interference with the cps so the enginewwouldn't start.changed the starter for a new one and it fired up first time
Try another crank sensor.
Ideally plug laptop in and using the Pectel software you will probably see the fault right away. Deskpro will show you the sensor readings and my guess is you will have zero RPM when cranking which would lead me to crank sensor.
Two simple things.
Check the ecu is getting power and ground. And then hook up a laptop to see if it responds
Steve, the fuel pump prime can be effected by dodgy crank sensor I have found when initial ignition priming on the Pectels.
But as you say. Hook laptop and descpro up to see what's going on.
Stu
Stu
On most ecu's, pump priming is a given. It occurs every time the key is cycled almost regardless. Ive never used a Pectel, so just going by what other ecu's do.
Spanner monkey
I would first of all send the ecu to either Ahmed / Mark at Grove, or Harvey at SCS, then i would go from there. If it's all clear, then happy days.
If it was ok before the alternator was charging at 15v, then i'd start there,
Maybe the overcharging of the alternator has fried the ecu?
Under the car...!
thanks guys,
robtt/polly_x
Funny you mention that as I have removed the crank sensor tonight and ordered a new one off ebay. I am really hoping that is the problem, but am not sure if it is or not.
Like Stevie says, I am surprised the pump isn't at least priming, but I know zero about Pectels!
The weird thing is there is 12v at the INJ pins on the ecu connnector, at the IGN pins, at the PUMP pin, and the earth tests out ok too. There is 12v to the ECU PWR pin as well.
I was under the impression that the ECU would recieved 12v power and then send power out via itself to the injectors etc? Im guessing I am wrong on this
Gadget - cheers. Ahmed emailed me back today and has said he will happily take a look at it. Which is good in one sense but not much comfort until I actually know what caused the damaged if it is damaged...
Once I have the new crank sensor I reckon that will tell all.... :/
I only have a crap old version of deskpro that needs Win 98 polly_x.
I cant get it to work on Windows 7 and even if I used a VM, my laptop doesnt have a serial port (my lead is rs232) so I will have to try and use my old XP laptop, which it still wont work on!! Has anyone got modern deskpro by any chance?
cossie fan (unluckerly)
Have you checked the lives and earths at the ecu and its out puts?
May be an idea to load test all the lives with a bulb then all the ecu earths with a bulb use a good 12 supply to rule out any wiring faults in the loom!
Checking with a muti meter can some times lead you away from a fault as you can get 12v's through 1 strand of wire. Testing with a bulb puts the wire under load and will show up a fault
Under the car...!
ajamessc// good idea mate. I will do this in the morning and report back findings against a pin out of the ecu connector
I cant do much else until the new crank sensor arrives I suppose. Is there any way to test the crank sensor? is there a resistance reading it should fall within does anyone know?>
Another thought I had while racking my brain, is that the clutch slave is right above the crank sensor on the car. When I bled the clutch on my own I just used a rag to catch fluid but it missed a load. I wonder if it shorted the crank sensor out...?
Always best to go with the free checks first lol
I've seen people quick to point at an ecu or components loads of times because of high resistance in a loom only to say I checked it with my multi meter lol
Not that I'm saying it will be that I don't no how that system works like the others say maybe the crank sensor or even the ecu but defo worth checking the wiring out fully if it dose point to the ecu!
Under the car...!
It might also help me get to the bottom of this nightmare!
Wirings not that hard if you have a diagram and the data to go with it!
At the end of the day it's just a component that will need a live and an earth that gives a signal or receives a signal too or from another component
Under the car...!
.Stuff has been altered though as it had a clifford alarm removed due to a battery drain problem (it wasnt the clifford). Then it had a new alarm fitted so Im still trying to get my head round it a bit.
For my last mondeo or another factory car I am ok with manufacturers diagrams and wire colours. But when all the wires are random colours or change colours along the way it gets fun!!not
But I'm geting there. I've got no option but to fix it myself!
Under the car...!
Right... I've been looking at this again this avo
Removed the crank sensor, 347 ohms across it. I don't know the stock reading but I am convinced it is not the culprit. Although I have a new one on the way.
I badly need to know if the pump should prime regardless of anything else when ignition is switched to ON.. I am going to ring Ahmed if I can get a number and ask him tomorrow before I send it off to him.
BUt basically, I have done a diagram showing my results for the pinout tests on the ECU connector (shown on the left of the picture). Either !2v, OK if the ground is complete, or '-' if not in use.
I used my lightbulb tester thing. When I tested across the pump terminal on the ecu connector... the pump primed... meaning I am thinking the ECU is the problem ???
I hope I am wrong. If anyone sees anything from the results please let me know. WHen I test one of the terminals on the fuel pump relay (one out of the 4 terminals does not have 12 v), the pump also primes.
What is ok supposed to mean ? And what does zero mean, and how are you testing ?
If pin 25 is the 5v reference out, are you getting 5v at that pin ? If so, the ecu would be deemed to be powering up.
Under the car...!
I was using an auto electrical light tester. Clip one end of the clip on to + or ground and point the probe at the point you are testing!!
Zero means I got ZERO Volts. BUt to be fair I was rushing this and did get a 2volt reading off one of the sensors yesterday with multimeter... will recheck it now.
I used a multimeter yesterday as mentioned and iirc I got 0v at the pin 25.... I will have to recheck it in a bit to confirm
cheers
A light tester would be useless, at a minimum you need a multimeter.
So zero doesnt mean zero...you just mean the light didnt light ?
And to say OK for 12v on a sensor ground from the ecu....clearly that is totally wrong.
The test is not valid.
Under the car...!
Right, I tested the whole thing with a multimeter the other day and was in a rush so was only really checking for power at the ECU. I briefly tested some other pins but didnt note voltage.
I have just retested the whole thing with my multimeter and heres the outcome...
(with regards to the light tester. I was following advice from a poster in this thread...I did think that a multimeter was needed hence why I used one initially, but thought it may be valid for things with 12v expected)
Yes, that's incorrect my saying 12v at ground...! what I meant was when I put the clip on battery + and the negative probe on to the ground terminal, the light came on. and opposite for the pins that were meant to have voltage. Maybe this is completely incorrect?!!)
Anyway, multimeter says:
(with ignition in the ON position)
Vref +5v termninal 25 = 5 volts
PIn 24 has 5 volts
Pin 23 ECT has 2.6V
Pin 22 TPS has 0.97 volts
Pin 21 CAM sensor has 0v
Pin 13 is an empty pin so cant be tested
Pin 12 - sensor ground - I got a resistance reading of 134 ohms with ignition on. I got continuity to an earth point on the car with ignition off
Pin 11 ACT has 2.6 volts
Pin 10 is empty - there is no lambda sensor..
PIn 9 MAF has 2.1volts
Pin 8 Crank sensor has 0 volts
PIn 7 RS232TX has 9 volts
Pins 5 and 18 (GROUNDS) I got a resistance reading similar to Pin 12 (sensor ground *approx 100 ohms). With ignition off I got continuity to an earth point on the chassis.
I hope this is clearer and please tell me if I tested something wrong (or am misunderstanding something) and I will retest once I know the right way. I am finding my way here.... I've not had to get into such meddlings before.
THANKS
When it comes to testing looms there's no better test than using a bulb as you can test each wire if you have a long earth lead to connect to ground and a power probe!
Under the car...!
I suggested using a bulb to test the wiring in the loom I.e load testing the wires not testing ecu out puts.
Misunderstood about the ecu pinouts! Never mind, only took 2 minutes so no harm done.
It does sound like the ecu is powering up. Otherwise you wouldnt be getting 5v out, and also the sensor inputs where you also see 5v....again, this is an indication the ecu is live.
When you test with a meter between 12v and fuel pump output, does anything register on your meter when you key on ?
Forgetting for a second that you dont actually hear the pump prime, which could be a faulty pump/wiring/relay.
I wouldnt put a bulb near any ecy output even for a test. An LED maybe, but not a lamp. ( ie power probe with an LED ) Many ecu outputs arent tolerant of loads across them, and a simple bulb could be too much for some.
Really laptop comms would be best option though, or get the ecu shipped off for testing
But lets face it, failed ecu's are very very rare.
Under the car...!
It would seem to indicate its not dead.. Though I'm not sure why I don't get any voltage from cam and crank sensor? hopefully Mr Bayjoo can help me out with this info!
roger that regards bulb testing ecu pinouts. Won't do that one again.. I will test pump output and post back.
I'm going to try and get deskpro working on my laptop. I've got an rs232 to USB 2 adapter coming and have setup a vm with win 98 on my win 7 laptop.. hope to hell it works lol . the rs232 comms of the ecu is simple as it gets so I hope the adapter works with it . Also hope the deskpro disc I got with the car and ecu has all the stuff I need to connect to the damned thing!! Will update this thread . If any other pectel t2 owners see this and use deskpro please post up!
Aussie Mondy Fiddler
Q), seen as no body has mentioned it, have you checked for power at the fuel pump,
Pump fuses / Relays etc, pumps can die for seemingly no reason depending on age/condition
Under the car...!
Adam. a good point indeed mate. no, there is no power at the fuel pump!! if I jump power to it, it runs. Also there is power at the fuel pump relay. I need to trace a wire going deep into the car that appears to signal the pump to run from the ecu I'm guessing. Will be investigating that more tonite . Have changed fuel pump relay and fuse for new with no difference mate.
I might try powering the pump direct and then see if the car starts?
Have you tested the crank and cam sensor with a scope to see if a signal is produced when cranking ?
Otherwise, you cannot tell if they are working or not. They generate their own power/signal. You could use a digital meter to get a crude idea if they are working or not though.
http://www.labscopes.com/index_files/Page550.htm
And as Ive said already, ignore the pump at the minute. Test the fuel pump output properly as Ive described.
