Transit problem
Old Mar 21, 2013 | 07:27 AM
Fordmad!'s Avatar
Fordmad!
Default Transit problem
Just recently i can go to start it, turn the key and nothing happens.
Turn it of then on again and it fires up straight My thought is that the barrel could be worn, it has done 192k
Its a 51 plate. Key isnt worn
Any ideas?
Old Mar 21, 2013 | 08:31 PM
Fordmad!'s Avatar
Fordmad!
Anyone?
Old Mar 21, 2013 | 08:52 PM
richbogle's Avatar
richbogle
Would realy need to check if the starter motor is geting power wen u turn the key. Transits are rife for starters!
Old Mar 21, 2013 | 09:49 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Put a multi metre on the battery turn the key and see if you get a voltage drop
Old Mar 22, 2013 | 07:09 AM
Fordmad!'s Avatar
Fordmad!
It dosnt happen very often only once every 10 times but want to sort it before it goes completly wrong!
Old Mar 22, 2013 | 07:35 AM
Does the imobilizer light start flashing on the dash.
Old Mar 22, 2013 | 08:21 AM
Fordmad!'s Avatar
Fordmad!
Wasnt aware it had a immobilzer and no don't think so! Its not it dosnt start its more of a delayed start. Got a new battery onto
Old Mar 22, 2013 | 12:11 PM
I could be wrong but i thought they had imobilizers on.
Old Mar 22, 2013 | 01:55 PM
Fordmad!'s Avatar
Fordmad!
Im not sure, dosnt have a fob or anything
Old Mar 22, 2013 | 06:34 PM
gingerturbo
Pull off the cowling and look round the barrel for a transponder
Old Mar 22, 2013 | 06:40 PM
Your key should be thicker than a normal one and they normaly have a blue bit at the top of the key where the imobilizer chip is.
Come to think of it when you turn the key and the light flashes,the next time you turn the key the light normaly still flashes so i dont think it is the imobilzer.I would check for power to the starter when the fault happens like said above.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
DAZZER
Sep 30, 2015 08:43 PM
Russ Payne
Sep 25, 2015 08:29 PM
