zetec in a mk4?? carbs or injection??
just picked up a mk4 bonus to start as a summer project...been looking at engines that dont cost too much as im on a budget. there seems to be plenty of 1.8 silver top zetecs around for not too much money. just looking for some info as to whats needed to drop the engine into my car? is the wiring the hardest part of the conversion?
would it be easyer to go down the carb route? bike carbs and manifold kits dont seem too much money
if i was to go with standard injection what other parts would i need?
any info much appreciated! https://passionford.com/forum/images/icons/icon7.gif
was thinking about going the carb route if i did put the zetec in, nuts and bolts im fine with but when it comes to the wiring im brain dead! whats needed to get the zetec running wiring wise when using carbs? im guessing id only need to get the ignition side of things wired in?
bike carbs i used cbr600 use either electric fuel pump and regulater or motorbike fuel pump an esc module and loom off late mk4 early mk5 mk3 fiesta not single point injection blacks live browns earth theres your spark my mate makes inlet on ebay pinkzeteccabby not that much ive build loads now and never went wrong
Ben
If you do go carbs, get bike carbs, they stay in balance far better than Webers.
Though, for the little extra work, and the far more refinement and better results, just go with ITB's.
For carbs, the easiest and most commonly used is Megajolt ignition, simply need a 36-1 trigger wheel, cam sensor if you want 3D mapping I think, and for carbs, you're better suited with something with at least a 38mm choke, 40 would be better, so GSXR 750 at the smallest.
That's what I can remember from my original plan, but was a while back so don't quote me on details lol.
Hello sorry to hijack the thread a bit but im currently putting a blacktop into my 90 spec 3i which allready has edis 4 wireing as standard.my question is can i pipe my map into the system to run my advance as its part of the standard engine managemaent
cheers
cheers
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
