Quick yes no answer needed!
Old Mar 13, 2005 | 11:52 AM
Rippers's Avatar
Rippers
Monte Geek
Default Quick yes no answer needed!
Mk3 doors the same as Mk4?? I need a new passenger door and been offered a S2 door? YES or NO
Old Mar 13, 2005 | 12:00 PM
tonyturbo's Avatar
tonyturbo
yes the same. needs a bit of a fettle where interior door handle goes but easy enough.
Old Mar 13, 2005 | 12:02 PM
BillyCabrio's Avatar
BillyCabrio
Nearly, same outer skin - inner skin is different.
IMO i wouldn't bother, wait for a mk3 door mate.
Old Mar 13, 2005 | 12:13 PM
Ginge !'s Avatar
Ginge !
just finding my feet
not the same , the inner need moding for the handle
can be done if ya fancy a challenge
Old Mar 13, 2005 | 12:17 PM
Ryan's Avatar
Ryan
no
Locking Latch is different hole pattern.
Inner skin is different
Old Mar 13, 2005 | 12:18 PM
tonyturbo's Avatar
tonyturbo
its easy enough to modify . you need a bit of flatbar about 50mm long to hold the handle in position.
once the door card is on you cant tell.
mk3 doors are hard to get now. its not rocket science to make it work.......
Old Mar 13, 2005 | 12:21 PM
Ryan's Avatar
Ryan
door locking is also different tony
BillyCabrio
No not rocket science, just hassle.
Or buy a normal door and weld some extra sheet metal along the B piler side of the door, thus making the door look wider.
If you fancy a challenge go for it Paul Ripley
Old Mar 13, 2005 | 04:43 PM
Rippers's Avatar
Rippers
Monte Geek
Cheers guys, I'll leave them and wait for a mk3 door, got enough stuff to modify without doing a door
Old Mar 13, 2005 | 04:52 PM
tonyturbo's Avatar
tonyturbo
the locking etc will swap straight over so i wouldnt class that as a problem. is if your a lazy coont.
Old Mar 15, 2005 | 02:49 AM
Rs Baz's Avatar
Rs Baz
paul im still waiting for info on that shell for you the lad that has it has
got loads of mark 3 escort turbo parts, for a matter of fact im sure he has
2 other s1 for breaking, will be in touch asap
matman
Sep 9, 2015 05:45 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
col93saphcos
Aug 7, 2015 03:21 PM
