Turbo shaft play...
Turbo shaft play...
Help!?
I have a turbo with some issues, the turbo shaft has absolutely no lateral play, but it does move back and forth, does that mean the bearings are fooked?
Many Regards,
Kieren
Many Regards,
Kieren
Well I measured it as 0.6mm, the shaft spins freely and like I said no side to side, but I dont want to put it up on ebay and end up with it back with negative feedback, if it needs a rebuild I can put that in the add.
im currently rebuilding a gt1749v of a laguna for my cousin, new shaft and wheel all seals and bearings/thrust.
its worn the comp cover rear plate aswell where the seal runns still only £120 though all in for the parts.
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
