focus 2004 auto fault code, could someone translate for me please
Hoping someone can translate this link into plain English as auto boxes confuse the fook out of me lol, checked the oil level which is fine as I suspected as it was changed only 2k miles ago, the car has only covered 48k miles.
Anyway the fault code is p0732 and here is a link I found
http://www.helpforcars.net/obd_codes/P0732.html
First of all, have you changed the transmission oil and filter. If that has been done you need diagnostic system so you can see transmission input speed, which should the same as the engine speed. If that looks ok, it's likely the the shift solenoid or wiring for 2nd gear is where your problem. It's not easy trying to diagnose these kind of problems through a forum
John
John
andrewmctiernan
08-09-2015 03:05 PM
