HELP Engine spec for 3dr
Old Feb 15, 2013 | 07:35 PM
3drRich's Avatar
3drRich
Default HELP Engine spec for 3dr
Hi Guys
Right after my last post regarding my engine spec shopping list Matt Lewis has come back with some good prices BUT i wanna make sure im getting the right stuff as back in the 90s we used to stick a massive turbo on and a adjustable boost valve and off we went
I would like to see 400bhp at the wheels so going for full engine rebuild with uprated bolts, bearings, 0.5 oversized pistons, group a gaskets etc also thinking airtec alloy rad & 60mm intercooler with siemens 55lb blacks and gt30 turbo, 3 bar map sensor, group a induction, uprated inlet cam, verniers, & a map by someone in the know! Do i need to do anything regarding the ECU?
Any help on this would be most appreciated
Old Feb 15, 2013 | 07:56 PM
Steve Escos's Avatar
Steve Escos
Speak to your tuner regarding your spec and ask their advice. ECU shouldnt need any modifying
Old Feb 15, 2013 | 07:59 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
As above, who isgoing to map it and what managment are you going to use? Is this the engine pete is building?
Old Feb 15, 2013 | 08:13 PM
bigchez's Avatar
bigchez
as above re ECU, but if you're having a new build the block & head should be flat so I'd go WRC/MLS gasket for peace of mind, and prob 6 long studs.
Edit - may as well get cut out's machined into pistons for cams too while you're at it.
Old Feb 15, 2013 | 08:16 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
As your in Southampton your best bet is to speak to m.a.developments it's about 45 mins away from you! Top advise and he will spec you what you need
Old Feb 15, 2013 | 08:19 PM
costina's Avatar
costina
Live long and prosper!!
^^^^^ good advice^^^^^^
Old Feb 15, 2013 | 08:43 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I would get a thicker intercooler to start with.
Also if your staying with the standard ECU get a L8
Steve
Old Feb 16, 2013 | 03:29 PM
3drRich's Avatar
3drRich
Cheers for the reply guys i was gonna ask of tuners local to me so might give M A Developments a ring.
Old Feb 16, 2013 | 03:31 PM
3drRich's Avatar
3drRich
Probably M A Developments as they seem the closest. Had a few people say the managment shouldn`t need to be changed but not sure about this?
Yes pete is building this for me, Do you know him?
Old Feb 16, 2013 | 03:47 PM
BRAMMER's Avatar
BRAMMER
STD 200 block inc 6 long stud, 4x4 pistons with valve cutouts, std/std crank, decent bearings etc, decent inlet cam and double springs.
WRC head gasket
Speak to M.A regarding turbo and management and injectors as i wouldn't fit 55's with a GT30 size blower
Old Feb 16, 2013 | 04:30 PM
bigluke200's Avatar
bigluke200
As above, I don't think 55lb injectors will see you the 400hp at the wheels that you are after
Old Feb 21, 2013 | 07:23 PM
3drRich's Avatar
3drRich
Right i think im decided know, let me know what you think ?
Full engine rebuild using group a everything and arp bolts all over
0.5 oversized pistons with valve cutouts
double valve springs
Bd 8 & Bd 14 cams
verniers
siemens 55 blacks
group a induction
group a fuel pump
t34.63 turbo
alloy rad
60mm alloy intercooler
live map
Looking for 400bhp so hopefully this will see it
Old Feb 21, 2013 | 07:24 PM
3drRich's Avatar
3drRich
400bhp at the flywheel that is
Old Feb 21, 2013 | 07:26 PM
costina's Avatar
costina
dont use arp head studs
Old Feb 21, 2013 | 07:31 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Would you not see 400bhp on std internals, surely it would be close?
t34.63
Greys
Rs500 intercooler
3 bar map sensor
and a live map on the correct chip?
Providing your engine is sound why go to all the expense?
Old Feb 21, 2013 | 07:33 PM
3drRich's Avatar
3drRich
Gonna use standard bud
Old Feb 21, 2013 | 07:34 PM
3drRich's Avatar
3drRich
t34.63
Greys
Rs500 intercooler
3 bar map sensor
True but wanna have the option to go more without taking the engine to bits again!
Old Feb 21, 2013 | 07:37 PM
DixieTheKid
Pick-up P100 Power!
where in southampton you from Rich?
3drRich's Avatar
3drRich
Been looking at a t04b Turbo. These anygood for 400bhp? much lag? Not heard of one before.
Old Feb 21, 2013 | 07:38 PM
3drRich's Avatar
3drRich
Surley you must know me Chris??
Old Feb 21, 2013 | 07:44 PM
DixieTheKid
Pick-up P100 Power!
Must do! Am i being a bit of a nob here? Do i know a Rich with a 3dr?
IF I DO......... THEN GET ROUND HERE AND TAKE ME OUT FOR A SPIN!
Old Feb 21, 2013 | 08:00 PM
3drRich's Avatar
3drRich
I would have a hard job bud its just a bare shell in the garage at the min
LEC PROJECTS??????????
Old Feb 21, 2013 | 08:04 PM
DixieTheKid
Pick-up P100 Power!
ahahahaha! Last convo we had you said that you cant be bothered with toys anymore..... get it sorted! Good luck with it fella, need anything?
Old Feb 21, 2013 | 08:07 PM
DixieTheKid
Pick-up P100 Power!
Ive got 3 or 4 3dr blocks here if you want to go .25 btw. All crack free.
Old Feb 21, 2013 | 08:10 PM
3drRich's Avatar
3drRich
Very true mate but no matter what i look at i always end up back in a cossie
Dont need nothing at the minute bud, just getting ready to paint the old girl OH and doing my plums on the lump LOL
Your p100 looking awesome bud whats next???
Old Feb 21, 2013 | 08:12 PM
3drRich's Avatar
3drRich
Jesus you collecting em????
just had my block bored to 0.5 , skimmed just waiting for matt lewis`s arrival now
Was gonna buy a built motor running 450bhp but wanna keep the engine numbers etc all the same.
Old Feb 21, 2013 | 08:15 PM
3drRich's Avatar
3drRich
Need any bits for yours i got another shell here and most panels for a 3dr??
Old Feb 21, 2013 | 08:20 PM
Sausage's Avatar
Sausage
Is it not worth dropping the CR slightly?
DixieTheKid
Pick-up P100 Power!
Yeah mate, I could do with a pair for grille brackets, a pas bottle bracket and a heater surround panel thingy bulk head jobo. A few other odd and sods.
Oh and a matching set of locks
Old Feb 21, 2013 | 08:33 PM
3drRich's Avatar
3drRich
CR ? am i being a din??
Old Feb 21, 2013 | 08:35 PM
3drRich's Avatar
3drRich
I only really have panels at the minute bud till i put mine back together!
DixieTheKid
Pick-up P100 Power!
Compression ratio mate.
Old Feb 21, 2013 | 08:40 PM
3drRich's Avatar
3drRich
Yep DIN lol
Old Feb 21, 2013 | 08:55 PM
shortie's Avatar
shortie
You'll be lucky to get siemens 55lb they have stopped making these now that's why i'm going greys on my upgrade
Old Feb 22, 2013 | 07:07 AM
BRAMMER's Avatar
BRAMMER
Speak to msd regarding injectors they are testing another kind or looking in to.
JoeyBoyden
Jan 4, 2024 02:36 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Oct 9, 2015 07:38 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
IAN RS2k
Aug 18, 2015 07:51 PM
