two fuel pumps?
is there any advantage of running 2 normal saffy 4x4 fuel pumps together instead of a 044 one, reason i ask is i got 2 pumps at home but i need a 044 one and have seen a few things about people runnin 2 fuel pumps in sequence or summit, whats the score with it and how dya do it???
I used to have two pumps in the rally car, and I think it's done purely on the basis that if one fails, you still have one there to get you back to service.
I was gonna run two lift pumps, and two fuel pumps, but I can't be arsed with stuff going wrong, so have just gone for the one group A.
![](https://img.photobucket.com/albums/0903/w3sl3y/FP3.jpg)
This is the Reyland Escorts old setup, two pumps on the left and fuel filter on the right.
If you have 2 new standard pumps then no reason not to use them in this way, but one Grp A pump is neater, also if it fails the engine stops, if you have 2 std pumps and one of them fails, well you can guess what might happen if 1 pump can't supply enough fuel for the engine...
I can't give specific advice on your setup, but generally 2 pumps are run in parrallel (wes's pic) as a fail safe system. A common cause for engines 'letting go' is lack of fuel (running lean). If you are running the 1 pump, and lets say it fails at 7k rpm...... The chances are the engine will have breathed it's last.
One thing i would advise, is use pumps that have enough fuel delivery for your engine, if used on their own, for the reasons above.
Om my last car i put a t piece on the tank in to two pumps in the orignal cradle then twin pipes to the front into two standard fuel filters under the bonnet then t piece into the fuel rail. Easy the return is ok as is. And i just crimped the second pump to the orignal cables. It made it sound a lot diff more burbely but i was running 8 greens and nos!.
It easy I done all m=ine in aeroquip but norm hose is ok
JK12
33
26-04-2021 12:09 PM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
