cvh zvh or zetec turbo help
Ive got problem with i cant decide what to build engine wise ive got a escort rs turbo that i have just bought with a knackered engine so have pulled it apart and found its totally goosed # 3 piston holed bore heavily scored ran to much boost i think and turbo shot so i have got a new turbo stg 3 hybrid for it now ive got a good cvh block
I also have a good 2.0 ltr silver top mondeo engine . So do i split that and build a zvh or just bulid the cvh back up or build a full blown zetec turbo
Any help from people that have done this would be appricated
Whats youre budget like?
Building upa cvh to take stg 3 power output may well be just as costly to build up zetec T to take smiliar levels. The zetec build could provide some form of futre proofing where as the cvh is relisticly going to need swapped out or extensivly modified if you feel you require more power down the line.
Bodger of Blackburn
whilst i love a zetec turbo, building up a cvh turbo engine is cheap and no hassle.
nothing needs modifying and can be up and running very quickly especially as all you need is an engine.
a zetec requires a lot more expense as IMO there is no point throwing a budget zetec together, unless you have a handy supply of standard engines and you're going for low power.
up until recently had a forged, cam'ed, gt30, frs box xr2, it went very well, but cost a lot as there were issues with lesser spec turbos, inferior clutches etc.
zetecs are brilliant, but the cost of doing it "right" isn't cheap, 3k on an engine to mid spec, £1500 on gearbox conversion and clutch (including electronic speedo), mounts and all that stuff, management, fuel setup sees another grand happily.
i think to get the car running whilst you build up a new power plant makes more sense, you've not had it driving, so need to enjoy it in good time.
Bodger of Blackburn
should be feasible, i have had cvh/zvh and the zt, nothing launches you like a zt, but i was chasing power in excess of 400bhp, i just never got it on the dyno sadly, but 2BAR of boost through one of those turbos is plenty quick.
i did have a cvh turbo and wasn't blown away, but with some work they can produce good power and some parts like IC (when upgraded) will be useable for more power in the future.
Zee Germans are coming
The standard series 2 metering unit will struggle safely at 240 it can be done but you will be ringing its neck so you may aswell get a cheap cossie management set up
So again you could always run the zetec on cossie management
The standard zetec with steel rods and decent pistons will run 300 with ease
And depending on how you drive you could still use the series 2 box
Awsome fiesta you got yourself
![](https://passionford.com/forum/images/smilies/roi.gif)
You are going to need a rod and piston package at that power on a cvh so you may aswell get a rod and piston package for that silver top 2.0ltr you have
Im not to harsh on gearboxes
It costs a fair bit when you add all the little bits up. I'm currently building mine up.
st170 engine was about £400
New zetec head and cams £300 (I chose new)
decent head gasket £100 (ford item has been on back order for ages\0
exh mani adapter £40
timing belt kit £40
sump gasket £40
arp rod bolts £60 iirc
sump mods cost me £70
then all the other little bits clutch, inlet, turbo upgrades, other gaskets and consumables, aux belt, modded engine mounts, mapping etc etc
Its gonna have cost me well over a grand and thats with already having megaquirt installed to run it.
i did sell the st170 head for £170 iirc
but it should sound a lot better than a cvh and less risk of it cracking its engine block.
timing belt kit £40
sump gasket £40
timing belt kit £40
sump gasket £40
timing belt kit £40
sump gasket £40
timing belt kit £40
sump gasket £40
timing belt kit £40
sump gasket £40
Guess I've been lucky with prices, I'm building 1 too,
![](https://i217.photobucket.com/albums/cc76/StuDaBear/zetec%20build/SSA51009_zps1359ac74.jpg)
Fittings were £5 each, plus the sump had to built up with weld on both sides, then drilled and tapped which was £60. Although this did also include a helicoil fitment into the frs top hat I'm using so I can use the cossie act sensor.
