What power
Hi all,
I currently have a Turbonectics T3/4E stage 2 F154 trim, on a .63 the car made BHP387@24psi.
Its a bit laggy for me so I am having a .48 turbine housing machined out to fit 54 turbine.
Does anyone have any exprience with this set-up, along with what top end flow would be in terms of BHP along with spool-up rpm etc?
The engine is pretty much stardard apart from-
1/grey injectors
2/3 inch exhaust
3/double valve springs
4/all nes to run over 400bhp
Any info on how the car will drive is much appriciated.
Cheers, T.
1/grey injectors
2/3 inch exhaust
Cheers, T.
i had a t3 with a stage 3 turbine wheel machine in a .48 housing and a 50 trim compwheel
on my rover run 20 psi and was in at 2200rpm around there was good not sure what it would have done flat out though spool was ok
![Smile](https://passionford.com/forum/images/icons/icon7.gif)
Anyone else ran or run this type of set-up?- or have any info on likely max bhp/spool-up Rpm?
More Info on turbo-
Compressor - Minor=2.122 inch Major=3 inch.
Turbine- Minor=2.126 inch Major=2.555 inch
Thanks for all/any info.
Cheers, T
More Info on turbo-
Cheers, T
Does anyone know if 350bhp is possible on above turbo spec's@26psi with ar.48 turbine housing?
I really what a punchy drivable car? I don,t know how to attach compressor map?
Thanks for any help. Tim.
Thanks for reply, I looked at the 55 housing but surely if I run 28psi I will be able to acheive 350bhp?
I ran 387bhp on a .63 @24psi, rpm 6509 and 323lbft @6066, dropped off to 360bhp @7800rpm.
Cheers , Tim
Cheers , Tim
Sorry to keep bringing it up , what does anyone think about previous posts? As Msd(stu says) it's not about boost but about how she breathes. What can the above spec on a AR.48 turbine housing breathe? Cheers, T
deathrider666
28-09-2015 06:12 PM
