Engine Paint Help?
Old Jan 24, 2013 | 07:05 PM
3drRich's Avatar
3drRich
Default Engine Paint Help?
Hi All
After some info on the best products to use to paint my engine and running gear?
Want to paint everything, bare engine, manifolds, pulleys, diff, Gearbox, Prop etc.
Any info would be appreciated.
Old Jan 24, 2013 | 07:14 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Powder coat your trailing arms, beam, x member etc.
I painted my block, pulleys and rocker with rattle cans, but put a high with a temp lacquer over the top. However the engine hasnt run yet but my mate who is a painter done the same (in white) and his still looks awesome some fews years later.
Interested in the comments on the diff as i still need to do mine and the gold bit on the drive shafts.
Good luck fella, where is Soton you from? You a scummer like me?
Old Jan 24, 2013 | 07:15 PM
Rsmat's Avatar
Rsmat
Gearbox was done in Pors-15 silver
And engine in satan black by hammerite
Diff was also same as gearbox
Prop was powder coated black
Old Jan 24, 2013 | 07:22 PM
Rsmat's Avatar
Rsmat
Old Jan 24, 2013 | 07:45 PM
dingla rs's Avatar
dingla rs
unless you know a very good powdercoater id paint the lot in 2k paint aluma blast made by frost.co.uk for diff an box ,I learnt the hard way my powder coat was wank so I repainted the lot in 2 k
Old Jan 24, 2013 | 08:09 PM
3drRich's Avatar
3drRich
Lovely Rsmat, Just what i want mine to look like. did you have to use any high temp stuff or etch primer for any areas?
Old Jan 24, 2013 | 08:10 PM
3drRich's Avatar
3drRich
I`m from you neck of the woods young Chris
Old Jan 24, 2013 | 08:19 PM
Rsmat's Avatar
Rsmat
Find yourself a proper powder coaters then mate ... Because if its prepped right and powder coated right it's bang on... Mines over a year old and 1400 miles of hard use and no chopping or flaking ... My best mate owns a powder coaters .
I used etch primer on everything that was rattle canned ..
If you struggle PM and ill text ya the stuff that was used ... But prepping it right plays a big part mate
Old Jan 24, 2013 | 08:23 PM
dingla rs's Avatar
dingla rs
Btw hammer rite is wank I wouldn't paint a gate
With it us 2k on ur block be fine etch primer first
Tho if you bear metal it
Old Jan 24, 2013 | 08:41 PM
3drRich's Avatar
3drRich
So etch everything? Is that ok to use on the engine and manifolds? and will everything have to be bare metal for etch to take?
Old Jan 24, 2013 | 08:46 PM
dingla rs's Avatar
dingla rs
etch primer is for bare alloy or metal ,if you not stripping them rite back just use a normal primer ,any bits that you do stip back etch
bit like this its only etched on bare steel (grey parts)
Old Jan 24, 2013 | 09:12 PM
matthewpickup's Avatar
matthewpickup
i just spent loads of time cleaning everything and the underside right back then primed it then used gloss paint and i have done around 2500 with no loss of colour or any paint chipping off .
do wish i just gave it to a sandblaster to get done would be alot less time/hassle
Old Jan 24, 2013 | 09:35 PM
Rsmat's Avatar
Rsmat
Done blocks with hammerite for years and so has probably 99% of PF without dramas
Old Jan 24, 2013 | 09:39 PM
matthewpickup
my brother used it on his engine block and its still the same as it was when it was done , that was around 6 years ago
Old Jan 24, 2013 | 10:06 PM
dingla rs's Avatar
dingla rs
It's still wank lol bet you etched it first
Il stand by what I say as Iv painted for 17 years it will
Never beat a 2k finish
Old Jan 24, 2013 | 11:12 PM
Rsmat's Avatar
Rsmat
Been good enough for me and most of the forum mate for years it lasts and looks good
Old Feb 17, 2013 | 04:45 PM
3drRich's Avatar
3drRich
I`d like to paint the block and cam cover in ford imperial blue. I know the cam cover will be ok just primed then painted but what about the block as i`d like to just paint as opposed to bare metaling it?
Old Feb 17, 2013 | 06:34 PM
dingla rs's Avatar
dingla rs
What's the block painted with before?
Old Feb 17, 2013 | 08:15 PM
3drRich's Avatar
3drRich
I dont think it is painted or its whatever it came from the factory with on it?
Its the original engine and dont think its ever been apart so maybe its not painted?
Sorry i would check but its not here!
Old Feb 17, 2013 | 08:32 PM
dingla rs's Avatar
dingla rs
Should be easy to wire wheel if standard stuff
Don't take a lot to clean it up mate
If it has been done before just primer the colour
Old Feb 17, 2013 | 08:55 PM
3drRich's Avatar
3drRich
Ok then etch prime and 2 k paint or will I have to use some sort of enamel or high temp stuff?
Old Feb 17, 2013 | 09:08 PM
dingla rs's Avatar
dingla rs
iv always used 2k should be fine mate
Old Feb 17, 2013 | 09:09 PM
SMILER258's Avatar
SMILER258
I painted all my rear end with hammerite. But that was because I could touch it up whenever it chipped off or got scratched. Now I would use 2k if I were to do it again
Kyle Langford
27
Aug 5, 2019 07:54 PM
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
Oct 9, 2015 07:38 PM
john_3.0s
Aug 16, 2015 06:40 PM
