is my car ok to drive?
i toke my escort gti to ford the other day for a service and they said that my front left spring was broken (standard jobbies), now thats fair enough but how can it be broken and me not notice? cos i been driving it everywhere and it feels fine not n and also its not lower at the front either to suggest its buggered either?
i havent had chance to look myself but it they said it was "broken" then i guess it would be pretty obvious just by looking at the spring?
having dodgy issues with my GTI too.... started creaking as I go round corners.... they came back to me and said that its teh bodywork rubbing on the wheel! it is lowered but I dont hink this has just miraculously started happening!
Hope you get it sorted mate, Ford eh... dodgy
my old motor had 2 snapped rear springs... i didnt really notice either!
if you take it very easy you should be ok to drive it to a local garage. i dont think its legal tho, especially considering you actually know about it. a set of springs (all 4) is about 60quid from memory. try here www.raldes.co.uk www.provenproducts.co.uk may aswell go for -25mm - -35mm jobbies whilst youre there, but you can still get std height ones if youd rather.
Baby Cheesus
Originally Posted by dvid
having dodgy issues with my GTI too.... started creaking as I go round corners.... they came back to me and said that its the bodywork rubbing on the wheel! it is lowered but I dont hink this has just miraculously started happening!
as for the spring, just take it easy till you get it sorted.
this is the rear of the car btw.... they said bushes were ok, he mentioned front arms but thought that they wouldnt cause noise in the rear... car has only done 47K miles too
cool thanks for that.... imaloverofcars, Sorry for invading your thread like abut rapist
Car should be ready to sell once I get it back.. had new emisions valve fitted as apparantly that was causing it to idle bad an cut out
A broken spring does not nessarily mean that is broken in half.. You probably wouldn't notice it.. 9 times out of ten a two inch section at the top of the spring will have broken away with excessive corrosion. Easy fix.. Get a suspension kit fitted..
Front left spring broke on the wife's Escort 1.8. Could only really notice it on full lock, but it didn't take long to swap it out.
The bushes in the front arms are a BIG problem. She got new Ford bushes fitted at the first MOT (only 16k miles). Two years and 12k later they were gone again so I fitted Powerflex bushes.
The MOT is almost due again and I think they have gone again - if so, it is back to cheap standard bushes for me - they aren't on her car for performance so I don't see any point in paying loads extra for the poly bushes if they don't last any longer!
Stu @ M Developments
41
21-08-2015 06:47 AM
CabrioTurbo
01-08-2015 11:04 AM
