Vw golf help needed!
Old Dec 11, 2012 | 07:29 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Default Vw golf help needed!
Hi peeps basically I've got s plate gt tdi golf mk4 battery died so I charged it then when I got back in the car my digital display usually you can flick through by a button on wiper stalk time temp mpg ect ect is stuck on the clock and when I press stalk doesn't do a thing? Any ideas I have just replaced the battery with a brand new top of range Bosch one today no change? Cheers
Old Dec 11, 2012 | 07:48 PM
BallsDeep's Avatar
BallsDeep
Not a fuse is it?
Old Dec 11, 2012 | 07:56 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
I checked the fuses they seem fine but I'm not sure which one is actually for the wiper stalk controls? It's doing my head in not having my mpg ect and the wrong time won't let me set the right time
Old Dec 11, 2012 | 09:16 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Anyone ?
Old Dec 11, 2012 | 09:38 PM
luke_rs1800's Avatar
luke_rs1800
usually you need to drive it so that they reset. and the clock usually updates itself. take it for a drive and see mate few miles. im a tech for vw.
Old Dec 12, 2012 | 12:03 PM
Aldis077's Avatar
Aldis077
I agree wit this suggestion. Some time the new things need some time to set in a running condition so i think you should run the car few miles and then it will be working fine. If not then you should check the wiring because it can also be a reason for that problem.
Old Dec 12, 2012 | 03:54 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
I tried the button again today on way to work its changed once then stopped again? Tried again after work and not working still
Old Dec 12, 2012 | 07:47 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Just been out and about again and still nothing the button doesn't do a think when pressed?
Old Dec 12, 2012 | 08:04 PM
pani_k's Avatar
pani_k
PassionFORD Member
Taking an assumption that all modern cars are the same, there is usually a module that does all of this. Nothing else hasn't suddenly stopped working has it that was working before? Do the wipers work?
Old Dec 12, 2012 | 08:06 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Yes mate wipers lights ect ect all work apart from this doing my head in !
Old Dec 13, 2012 | 08:57 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
another 10 miles today still no joy
Old Dec 13, 2012 | 09:07 PM
16imarty's Avatar
16imarty
try diconting battery for a minut then recont
Old Dec 14, 2012 | 07:38 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Tried that mate no joy
Old Dec 14, 2012 | 10:45 PM
vaughant's Avatar
vaughant
Check any stray earths around the battery area, I had this before on a mk4 gti 2.0 l but I lost all clocks,dash lights etc yet the car started and ran fine. Towed it back to the workshop and found a few earths had come off (iirc they go to a block below the battery tray). Cleaned some connectors up and renewed the eyelets and she was great. It had been crash damaged and this was after the lad had removed the battery to pull the leg hence I`m wondering if its the same thing.
Old Dec 15, 2012 | 06:26 AM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Ill take a look cheers bud
JoeyBoyden
Jan 4, 2024 02:36 PM
paceo
Feb 3, 2016 10:31 AM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
paceo
12
Aug 4, 2015 08:50 PM
