FAILED MOT :(
FAILED MOT :(
still cant get TAX
basically failed on front wheels rub chassis on full lock
emissions - i just need to put cat back on...
and the rear brake pipe corroded, the metal one, this is the bit that im fukked on.
where can i get another brake pipe????????
oh, got the water bill today too, another £235
i got no money either
speak to DOO about a break pipe or ask lewis to ask him
mr mot is in centre of britstol
its a trek for you but it will pass if its just a bit of rubbing and emissions
my cossie passed before it was setup with a similar emissions problem
i reckon the brake pipes are copper ... hence the corrosion... so u should be able to grind the corrosion off of it ! ...................... or am i mistaken ?????
he said it had gone to thin, so i guess it could do with replacing...
i aint looked yet, prolly have a look at the w/e
oh, also he noticed that the floor pan was ripped away from the sill, looks like the c*nt who last fitted my tyres jacked it up on the floorpan not the chasis rail
was going to post summit but thought better of it as i may get into trouble if it was seen by the wrong eyes if you know what i mean
i'll word it this way, do you not have a FRIEND or know a FRIENDLY GARAGE that could HELP YOU???
still, at the end of the day, if i need a brake pipe, ill need one..
the rest, ie cat back on and borrow some wheels aint hard...
and id rather get the brake done proppa as its quite essential.
brom, i can fit/bleed brakes no probs, its just i dont know if it comes fom the master cylinder all the way to the rear brake line, or if there are joins in between??
ill have a look tomoz nite and get back to you
cheers mate
phil robson if i had the fookin wheels i would lol
i got esc cos front brakes too so i dont think a 13" steelie will fit..?
cheers mate
SMILER258
28-09-2015 09:04 AM
