Amal valve problems..... maybe......maybe not..... probably!
Old 09-03-2005, 03:39 PM
palmer3914
palmer3914's Avatar
Default Amal valve problems..... maybe......maybe not..... probably!
Put smits amal valve on mine today and it was smoother boosting and only @18psi, while put mine back on and its nothing nothing nothing nothing!!!! 24psi!!!!! and at 20-21 it cuts and then carrys on ........ and when dis-connected my amal valve and then run the car - NO DIFFERENCE same boost same lag!!! would this mean my amal valve is FCUKED!!!! or could it need to be re-jetted as mine would only seem to have 1 jet and thats it...... or should i just get a bleed valve ???? ideas's / help / opinion's / abuse all wanted!!!!
Old 09-03-2005, 03:43 PM
palmer3914
palmer3914's Avatar
up
Old 09-03-2005, 04:13 PM
palmer3914
palmer3914's Avatar
and again
Old 09-03-2005, 10:56 PM
palmer3914
palmer3914's Avatar
one last time to get some attention!!!!!!!!
Old 10-03-2005, 12:27 AM
Smit
The 60ft Launch King
Smit's Avatar
DON'T run a bleed valve. They are dangerous!?!
Stop being a tight mofo and buy a new one!
Old 10-03-2005, 08:43 AM
palmer3914
palmer3914's Avatar
ha ha ha, its a learning curve!!!!!!!!! i will buy one as soon as i determin its the amal thats fcuked!!!! and thanks again for the "loan" of your amal valve dude.
Old 10-03-2005, 08:53 AM
Nik_W
Nik_W's Avatar
Sounds like you amal valve is knackered, I had the same problem with my previous Saph Cos. All the power came in at once and it wasn't until around 4000+rpm. Put a new amal valve on and it was back to normal.
Old 10-03-2005, 08:55 AM
Jim Galbally
Jim Galbally's Avatar
absolutely NOTIHNG wrong witha bleed valve whatsoever. It's only when you out them in the hands of idiots that start twiddling (like me )
look in the FAQ / Essay sections there are some big posts about amal valve control and it'll answer all your questions
Old 10-03-2005, 08:58 AM
Nik_W
Nik_W's Avatar
bleed valves are sometimes used to rectify problems elsewhere though. I tried it on my S1 when I was having boost problems, but then realised it was better to fix the problem than solve it with using a bleed valve.
Old 10-03-2005, 09:01 AM
palmer3914
palmer3914's Avatar
fair enough thanks guys....... where's best place to grab a amal valve then????? anywhere close (ipswich)
Old 10-03-2005, 09:06 AM
Nik_W
Nik_W's Avatar
rob one from a RS Turbo
Old 10-03-2005, 09:15 AM
Jim Galbally
theyre only about a tenner
Old 10-03-2005, 12:49 PM
Smit
Smit's Avatar
Jim - Talking about cossies here! Without the amal valve connected the ECU has NO controll over the boost if something was to go wrong!
Old 10-03-2005, 01:25 PM
Jim Galbally
smit, i know
but do you realise how few off the shelf chips even have amal control enabled anyway
Old 10-03-2005, 02:19 PM
Smit
Smit's Avatar
Main thing here is Matt doesn't want to blow his car up again!
Old 10-03-2005, 03:24 PM
Jim Galbally
then he should go nd get it set up by a pro instead of taking DIY advice off of a website
Old 10-03-2005, 07:20 PM
palmer3914
palmer3914's Avatar
easy tiger!!!! i am !!!!! as of 9am tomorrow (friday)
And ill be interested in finding out what is up with it!!!!
But you guys have all been very helpfull!!!!
Old 10-03-2005, 07:26 PM
Smit
Smit's Avatar
Jesus Christ Jim - Pot - Kettle - Black -
steve.rst
15-03-2016 08:01 AM
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
rs_jim
19-09-2015 08:41 PM
Quick Reply: Amal valve problems..... maybe......maybe not..... probably!
