2ltr Zetec engine torque settings
has anyone got a haynes manual handy that they could scan in and post up on here the pages with the torque settings on for me
the engine i have is a silver top Zetec-E from a 1998 mondeo
havent got a haynes handy and would like to build it up today if poss.
cheers
cheers
do you mean the duratec one mate?
think mine is a 94 2.0l
anyway, head bolts are 45n/m then angle tighten 105 degrees.
con rod bolts are 18n/m (i think
) and angle tighten 90 degrees
cam bearing cap bolts are 19n/m
cant quite remember big ends, think its 45n/m
waterpump 10n/m
oil pump 10n/m
HTH but prolly not lol
waterpump 10n/m
oil pump 10n/m
Here we go then:
main bearing cap bolts and nuts 80n/m 59lbf/ft
crankpin (bigend) bearing cap bolts
stage 1 18n/m 13lbf/ft
stage 2 angle tighten 90 degrees
oil spray jets 10n/m 7lbf/ft
cylinderhead bolts
stage 1 25n/m 18lbf/ft
stage 2 45n/m 33lbf/ft
stage 3 angle tighten 105 degrees
stage 1 10n/m 7lbf/ft
stage 2 19n/m 14lbf/ft
camshaft sproket bolts 68n/m 50lbf/ft
cam cover bolts
stage 1 2n/m 1.5lbf/ft
stage 2 7n/m 5lbf/ft
timing belt tensioner bolt 38n/m 28lbf/ft
timing belt guide pulley bolts 38n/m 28lbf/ft
oil pump to block 10n/m 7lbf/ft
sump bolts 21n/m 15lbf/ft
flywheel bolts 110n/m 81lbf/ft
crankshaft left hand oil seal carrier plate 22n/m 16lbf/ft
if you need anything else mate gis a shout, i got the manual here now if you aint guessed lol
cylinderhead bolts
cam cover bolts
JoeyBoyden
Jan 4, 2024 02:36 PM
