brembo brackets and fit cosworth wheels
Old 24-11-2012 | 04:40 PM
corkers's Avatar
corkers
Default brembo brackets and fit cosworth wheels
Hi iv got a s2 and got hold of some Focus RS calipers iv been looking at some bracket on ebay http://www.ebay.co.uk/itm/Ford-Focus...item4abe5e038c has anyone used these? or know of any that are better?
also would they fit behind escort cosworth wheels if not i also like the comps mo5's will they sit behind 16's or do i need to get 17's thanks . . .
. . . i have tried to search this and only really found they sit behind comp 17's for def
so any advise or pics would be greatful
cheers, nick
Old 24-11-2012 | 05:44 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
which discs are you planning on running?
i managed to get a full frs setup behind rota competition 16" wheels on my xr2, they are quite spacious wheels on the inside, can't see many out thee being able to accommodative frs brakes under a 17 to be honest.
i had to trim quite a bit from the calliper and leave one mm of space from disk to internal calliper to fit them. it could be a lot of work, unless you turn the disc down 5mm or so.
Old 24-11-2012 | 06:32 PM
corkers's Avatar
corkers
i was goin to used the focus discs the 324mm aren't they?
Old 24-11-2012 | 08:52 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
they are indeed 324mm, you will be lucky to get them behind 16's, i struggled and had to shine the callipers somewhat with tools. i ended up with less than a mm between callipers and wheel/wheel weights. with the previously mentioned alloys, most do it ok with 17's, just gives 12.7mm more room to play with, dependant on inner diameter.
Old 24-11-2012 | 09:23 PM
corkers's Avatar
corkers
ok cheers for that, i guess they will have be the 17's then . . . i dnt suppose you know about the brackets?
JoeyBoyden
04-01-2024 02:36 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
14-08-2015 07:29 AM
RsS2daz
14-08-2015 05:26 AM
lockie
31-07-2015 10:03 PM
Quick Reply: brembo brackets and fit cosworth wheels
