FAO tuners & engine builders or anyone in the know.
Old 26-09-2012, 02:20 PM
  #41
stevieturbo
C**t
stevieturbo's Avatar
Originally Posted by fraser9764
What on earth are you on about?
You said inlet pressure rises but boost stays the same.
This is what I said was confusing as 'boost' is just differential pressure between atmospheric and inlet.
It rises, it falls, it rises it falls. It's dynamic, it is always doing this. That's what boost control is there for. So it doesn't go too high or too low. Just because you don't understand doesn't mean it isn't happening.
Old 26-09-2012, 02:35 PM
  #42
Rsmat
300+
Rsmat's Avatar
I want boost like this... In my cosworth
Old 26-09-2012, 02:41 PM
  #43
fraser9764
fraser9764's Avatar
Again WTF are you on about.
You don't need to explain the dynamics of a very basic closed loop (in some cases) control system to me.
All I am trying to get you to do is explain your original comment that the inlet pressure rises but boost stays the same.
They are the same thing, how is one increasing and the other staying the same?!
Old 26-09-2012, 02:50 PM
  #44
Derby_Gav
Derby_Gav's Avatar
Would a 50 or 75bhp nitrous kit not make more sense to give you the massive power spike you want?
Old 26-09-2012, 05:48 PM
  #45
Rsmat
300+
Rsmat's Avatar
No.......
Old 26-09-2012, 05:58 PM
  #46
Turbosystems
Super Moderator
Turbosystems's Avatar
I'm interested in his explanation too
what do you know about electronic control systems you only do them for a living
Old 26-09-2012, 06:06 PM
  #47
stevieturbo
C**t
You say you understand how a closed loop system works yet you cant understand how it works ?
So lets repeat the very simple statement I made. Can you read English ok ? Ive highlighted a key point in case you didnt go to Specsavers.
"It will raise inlet pressure....except the same pressure still controls the wastegate so boost will remain as normal
Old 26-09-2012, 06:07 PM
  #48
Fiesta_Jed
Fiesta_Jed's Avatar
If I wanted a big power low lag 3dr, I would fit a ford 302 v8 with a standard bottom end and the appropriate head work and A cheap ebay gt40something turbo with quick spool valve in the boot.
500bhp and 500+lb/ft
Not an ideal solution for a car as clean and original as yours though...
Old 26-09-2012, 06:08 PM
  #49
stevieturbo
C**t
http://www.youtube.com/watch?v=rp6DZ...e_gdata_player
OK..This thread really is a wind up. There is a very minor issue in that car is making over 1000bhp. So if you want it to behave like that, you too will need to make over 1000bhp.
Old 26-09-2012, 06:33 PM
  #50
Rsmat
300+
Rsmat's Avatar
Steve let me fucking repeat myself once again Mate... This is NOT a wind up... I just like the sound of lots of boost... That's only a 1.8 also.
Old 26-09-2012, 06:34 PM
  #51
stevieturbo
C**t
That car doesnt sound the way it does because it makes lots of boost. It sounds like it because it has over 1000bhp !!!!!
And it sure as hell wont be low lag.
Maybe Fraser can help, seems he is a boost control wizard.
Old 26-09-2012, 06:39 PM
  #52
Rsmat
300+
Rsmat's Avatar
Cheers mate... That's probably the best answer you've come up with... Ask Fraser ... Cheers....
I understand mate... I'll just stuck with what I've got as I'm happy with it just I would have built a boost monster just to be different if it had been possible.
Old 26-09-2012, 06:46 PM
  #53
stevieturbo
C**t
It is possible ( although perhaps not on pump fuel )...but it would be completely and utterly pointless. And a low power engine with lots of boost is not going to sound anything like the car in the video
Old 26-09-2012, 07:03 PM
  #54
Rsmat
300+
Rsmat's Avatar
I know mate... Shame really as I like a violent car.
Old 26-09-2012, 07:12 PM
  #55
stevieturbo
C**t
What you want is a powerful car. But you have to remember you are still 2wd ( I assume ) so traction will be the biggest limiting factor if you do go down that route
The Golf in the video is 4wd.
You could easily build a setup that will smoke the tyres in most gears with ease and never go above 30psi.
If you just want a car that makes lots of noises, just build one with a decent turbo, slightly louder exhaust and maybe a screamer pipe from the wastegate.
But until it's making some decent power, it will always sound tame no matter how much boost it makes.
A low-moderate boost setup built as a high revving engine would probably make better noises for you, although low end will suffer a bit.
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
costina
18
25-08-2015 06:02 PM
Quick Reply: FAO tuners & engine builders or anyone in the know.
