cosworth backfire
old school is good
cosworth backfire
Just built new engine and been mapping it. All is well untill about 6000rpm. It has a backfire for a few revs then clears up on load and in neutral. Number one plug is always coaked up black. We've checked /swapped injectors. Plugs, coil, leads,the map looks spot on. Any ideas please I'm lost now.
When dose it do it when you floor it or when you drive it up the revs slow . I ask this as my 3dr had this for a long time it would drive spot on all the way up the revs but when i booted it it would back fire hi up in the revs . It turnd out to be the leads were bracking down and they were to close togever when i moved them apart it sorted it i did put a new set on when i found this out . im all so running wasted spark
Its the coil pack mate
im bilding a focus cosworth and we started it up for the first time about 4 weeks back and number 4 was not running right it was sparking but not firing the plug when it was in the head so i put the coil pack on the wifes KA and that run the same . i put a brand new one on and it ran spot on
Adam Graham
06-09-2015 06:04 AM
