Zetec tubular manifolds..
Old 01-09-2012, 06:57 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Default Zetec tubular manifolds..
What thickness flange is yours?
I had one cut on our laser, but did it out of 8/10mm(can't remember which), but my old man went to a kit car show a few weeks back and people were selling them out of 6mm? Seems a bit thin to me
Also, what size tube is best used for the primaries?
Thanks
Ben.
Old 02-09-2012, 10:44 AM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Anyone?
Old 02-09-2012, 12:48 PM
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
if the primarys are long then 1.5 inch will be fine upto 500bhp , but if you used a larger tube like 1 5/8 with short primarys (like a focus rs manifold) then you would probably gain a few bhp but the torque would rise .
i use on my over gearbox manifolds 1.5 inch primarys , 1.5mm thickness and 10mm thickness stainless steel flanges both header and turbo flange
even the 10mm stainless flanges are bolted down during welding to stop the flange from twisting
hope this helps
Old 02-09-2012, 12:54 PM
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
My twin scroll top mount setup uses a 12.6mm (1/2") mild steel flange and 4mm wall thickness primaries.
Admittedly it will have a harder life than most, hence the 'meatiness' of it all...
Old 02-09-2012, 03:22 PM
gus
gus's Avatar
Now that looks cool
Old 02-09-2012, 03:33 PM
v man
Zee Germans are coming
v man's Avatar
I have one of ian Howells manifolds
Great bit of kit
Old 02-09-2012, 06:08 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Thanks for the replies guys, I should of said what spec I'll be running!
I'm building a KA with a 2.0 Zetec, very lightweight and basic breathing mods and cams for the time being, as we have a pipe bender and laser I figured we could make our own exhaust including the manifold, so at the very most, 150bhp for the time being which should be more than enough while I source some parts for a turbo conversion.
Ben.
Old 02-09-2012, 06:21 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
what kind of pipe bender?
if it's not a mandrel one don't bother IMO.
Old 02-09-2012, 08:47 PM
CrOwSoN15
Ben
CrOwSoN15's Avatar
Yes it's a mandrel mate.
mk3ste
17-10-2021 10:09 AM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
SMILER258
28-09-2015 09:04 AM
mondeomark
28-09-2015 06:28 AM
focuspower
20-09-2015 03:51 AM
Quick Reply: Zetec tubular manifolds..
