Engine Coolant boiling problem
Old Sep 3, 2012 | 12:25 PM
  #41
Brendan's Avatar
Brendan
struggling with reality
have you checked the radiator for blckages ? also does the fan kick in?
Old Sep 3, 2012 | 01:00 PM
  #42
Jasoncmor's Avatar
Jasoncmor
The fan does kick in, yes.
Also I'm unsure weather the radiator is blocked or not, I assume its OK, I can easily pour water in the expansion tank and it will come pouring out the bottom drain hole. If I use a hose pose to add a bit more pressure, the water squirts out all over the place with greater pressure. So either I thats what you mean for blockages or I've not checked it.
Jason
Old Sep 3, 2012 | 05:16 PM
  #43
Jasoncmor's Avatar
Jasoncmor
Well flushed the heater matrix out, installed a new heater control valve, heater works great now, just gotta keep an eye on the engine heating up.
Turns out I also didn't screw the expansion cap on tight enough, its very tight now and seems to hold the pressure much better now.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
muffster
Aug 17, 2015 08:17 PM
