Need yb conrods ..
Need yb conrods ..
After taking my yb rods to have new smallens bushes
I was told that the big ends are out of shape ( oval'd ) .
So nows perfect time to ' up rate' them .
I've been looking around and found these on eBay by a company called PPM
Item number 270493252498..
They look and sound the part but
Has anyone had any dealings with these ppl or no someone that has??
Any help would be appreciated
Super Moderator
unless you are changing the rod ratio use std cosworth rods these were designed and manufactured by COSWORTH and have no horse power limitation on a yb as the rest of the engine will disintegrate first
the standard cosworth rod is a serious over engineered piece of kit
but what do cosworth know about engine design
there is nothing std about an original genuine cosworth part
you are more likely to be down grading by trying to upgrade
Cheers guys .
Tony I was planning to use my std rods but after
Taking them to be re bushed etc the machine shop
Said the big ends wer out of shape!
I no the std rods are very good and developed by
Cosworth and all the rest of it . I'm not changing
Cos I WANT to I'm changing cos I NEED to .
And was asking for help with choosing a decent set of rods..
Howard u getting on with my supra diff :-D
Ok cool.. Do u no How long so I can get courier sorted ??
It's a 4x4 engine I bought about 2 yrs ago it's just been sat waiting for me to do something with it .. I had it taken apart an it had spun a big end at some point and scored the crank so had that a grind on big ends and mains so all nice an fresh .. If I could get hold of a good std set of Cossy rods for not much money then yeah I'd get std. ..
Yeah tony it was number 4 that's the worst but all 4 are outta shape..
I have my sump all wrapped and ready for you . I'll send it with courier when he picks diff stuff up ok ..
Regardless of what sump is fitted it is always No4 that is the most prone to failure
No4 is the furthest big end away from the oil pump and is the most likely to fail
If your oil pump sucks air (hence the need for dry sump or an efficient gated/baffled sump) then No 4 is gonna pay the price
