Can some one explain amal valves to me ?
as the title, thought i knew what they were about but wondered if i'm missing something ?
they are an electrically operated bleed valve
mine seems to have been disconnected on one side (air pipe) & the pipe sleeved down to leave a smaller hole & the other pipe is completely gone, i'm fairly sure that when i had it on the rollers at power engineering the guy said they were crap & did something with it then but i may be mistaken, so basically its now only got the electrical connection to it ??????
it depends how you connect it up.
1 Pipe from turbo to actuator with bleed valve on pipe=no amal valve.
2 As normal with amal valve connected with all 3 pipes but the pipe to the turbo cut and a blled valve fitted to this pipe
Personally i would just adjust the actuator and leave it
