Help please
Old Mar 5, 2005 | 04:37 PM
K1NFSCOSSIE's Avatar
K1NFSCOSSIE
Default Help please
Spent a day trying to start my mates cossie to no avail, wondered if anyone had any ideas.
Car was fitted with light blues but changed to greys recently, was all running fine, then while just sitting on tickover it died and won't restart.
today we have checked fuel pressure (55psi on closed system)
theres spark,
theres fuel in the bores
the injectors are pulsing
there are no air leaks (that we can see or hear)
timing is spot on
all leads and wires are on
theres sufficient compression in each cylinder
can't understand how there is fuel/spark/correct timing, but no bang.
car previously had knocky lifters and the last time it started it sounded sweet with no tappety noise at all.
possible thoughts from others are that the lifters are jacked and the fuel is just bypassing everything, but i would have thought it would at least try to start rather than turn over and over it has big valve head and bd14's so not sure if this could be the reason.
peoples ideas and thoughts would be appreciated.
ps. already thought of the Crank position sensor, but as stated got spark and injector pulse.
thought possibly something has gone down in the ECU but if you've got fuel/spark/air then you should get a fire!!!!
Old Mar 5, 2005 | 05:15 PM
K1NFSCOSSIE
Old Mar 5, 2005 | 05:17 PM
Ryan's Avatar
Ryan
were the plugs very wet? could try changing them if you have a spare set
Plugs could be getting saturated, I.e wrong plugs for grey and boost setting, or heavy fueling on idle
Old Mar 5, 2005 | 05:22 PM
K1NFSCOSSIE
brand new all supplied with the greys, huge spark can't think what ones they were but as stated it was running fine previously
Old Mar 5, 2005 | 05:23 PM
martinmace's Avatar
martinmace
i had this problem today, may sound weird but i disconnected the tps and the fucker started, plugged it back on and its fine now
Old Mar 5, 2005 | 05:30 PM
K1NFSCOSSIE
Ok cheers will try it tomorrow, did you have fuel and spark though before??
Old Mar 5, 2005 | 05:38 PM
martinmace's Avatar
martinmace
yeah all ok spark, fuel, it just died and wouldnt start again. it didnt even try to start just kept turning and turning. i only disconnected the tps to blow out any water or moisture that may of caused problems and thought i wonder if it will start without it being connected and it did....just like that . worth a try mate.
Old Mar 5, 2005 | 05:40 PM
K1NFSCOSSIE
cool will give it a go, thanks a lot
